Home » Community » Post Production Techniques » Attach swarovski crystal: best material & glue?
Attach swarovski crystal: best material & glue? [message #57269] Thu, 22 November 2012 11:21 UTC Go to next message
avatar DavidMulder  is currently offline DavidMulder
Hi, I am planning on creating a pendant quite similar to http://www.crystalclassics.com/images/1515873-1.jpg , however I never did such a thing before (the swarovski part, I lost my old account, I am not new to the entire 3d printing business Razz), so any advice or experiences would be extremely appreciated. Or if you have seen any tutorials out there I would love to hear about those too Very Happy .
Thanks a lot in advance, David Mulder
Re: Attach swarovski crystal: best material & glue? [message #57707 is a reply to message #57269 ] Thu, 29 November 2012 23:15 UTC Go to previous messageGo to next message
avatar cnaind  is currently offline cnaind
Hi David,
regardless of which material or glue you use, getting both parts completely clean is a must. Once that is accomplished, I would recommend an adhesive that dries crystal clear such as Devcon 2 part epoxies which will also offer max strength. You can also use UV cure adhesive if you have access to a UV lite. Stay away from "super glue" as they tend to be a bit cloudy and/or may frost the crystal when cured. You can also use clear, 100% silicone sealant but only a very tiny dot is necessary.
Hope this helps.
Alan
Re: Attach swarovski crystal: best material & glue? [message #62666 is a reply to message #57707 ] Sat, 23 February 2013 21:38 UTC Go to previous messageGo to next message
avatar PeregrineStudios  is currently offline PeregrineStudios
I've used some swarovski flatback rhinestones on WSF before and just used superglue, which holds very well. On Stainless Steel or Sterling Silver I couldn't tell you from experience, however I understand superglue would still be fine (as long as you sanded the area where you are gluing the rhinestone first).
However, that's mainly been with pieces with one large rhinestone in the center, as opposed to many small ones littered throughout. Take it with a grain of salt.
Re: Attach swarovski crystal: best material & glue? [message #64573 is a reply to message #57269 ] Thu, 21 March 2013 12:43 UTC Go to previous messageGo to next message
avatar Invicta_NC  is currently offline Invicta_NC
Hi David,
I don't have any experience with printed items yet (waiting on my first print now). However I have quite a bit of experience with Swarovski crystals in helping my wife with her jewelry hobby and years in the hardware trade.
2 part epoxy glues (Devcon etc) are perfect for attaching crystals. Ensure you get glue that dries clear and be sure to mix equal parts. The most problems/complaints people have with 2 part glues stems from incorrect mixing, causing non curing, rubber cure or brittle cure.
Cyanoacrylate (Super Glue) has limited shear strength and will break if exposed to a shock. (dropping item on a hard surface sending shock waves through the piece this is usually enough to break the bond. Thick (gap filling) CA's are more resilient to shocks than their thinner counterparts. Also beware of "frosting" on surrounding surfaces this happens when CA fumes evaoprate (although this is a good way to bring out fingerprints Smile )
Clear general purpose (UHU glue) are a good choice but the stringing effect can be a pain to work with if you're using small parts/crystals.
My choice would be 2 part Devcon.
Malc.
Re: Attach swarovski crystal: best material & glue? [message #64579 is a reply to message #64573 ] Thu, 21 March 2013 13:39 UTC Go to previous message
Hi Maic,
By now I already finished the pendant for quite a while ( http://www.shapeways.com/forum/index.php?t=rview&th=1212 4&goto=59094 , I wrote some very basis stuff about my experiences as well with the glueing ) , but thanks a lot for sharing your knowledge Very Happy . I used E6000 which did (so far) a perfectly fine job, as I haven't heared about any of the crystals getting loose or anything along those lines.
Thanks again,
David
Previous Topic:How to use automotive paint?
Next Topic:Help with Ball Joints for action figures
