| New Flower [message #56991] Sat, 17 November 2012 11:42 UTC |
Hello
Heres a new design. This version is only for from/fit testing. Later revisions will be lit. The stem consists of 2 interweaving (not connected) layers, and a cored centre to allow for either a single LED or a larger diameter fiber optic. The flower is hollow with a hole at the base . Stem and flower connect with a simple push fit. Yet I think i will change this to a ball and socket for added stability.
Ill offer a version of this unlit through shapeways so people can DIY or just use it as an ornament .
Im pretty sure but WSF wont conduct electricty right? And that warning on the side of the newer boxes, that reads ' The products should not come into contact with electricty' doesnt apply to wires that are properly insulated?
Oh BTW from order to receiving was 5 days ......and i ordered on a Sunday. Nice one Shapeways.
EDIT: The dimensions for the flower alone are:
In: 2.6 w x 2.6 d x 2.4 h
Cm: 6.5 w x 6.5 d x 6.0 h
Attachment: 2.gif
(Size: 240.40KB, Downloaded 228 time(s))
Attachment: 1.gif
(Size: 180.98KB, Downloaded 229 time(s))
Attachment: 4.gif
(Size: 193.38KB, Downloaded 228 time(s))
[Updated on: Sat, 17 November 2012 11:49 UTC] formerly known as pdb
| Re: New Flower [message #57104 is a reply to message #56991 ] Mon, 19 November 2012 18:08 UTC |
Thanks Bart
Any chance you know what the minimum internal diameter of a tube has to be, if the wall thickness is 1 mm? If the, 'Usable area in the relation wall thickness / hole size' from the advance design rules can be used then i guess it's anything over 2mm.
Regards
Oh n heres a couple of tests i did......sorry for the bad quality photos. Think my camera is afraid of the dark.
Attachment: 5.gif
(Size: 230.76KB, Downloaded 133 time(s))
[Updated on: Mon, 19 November 2012 18:23 UTC] formerly known as pdb
| Re: New Flower [message #57127 is a reply to message #57104 ] Mon, 19 November 2012 23:57 UTC |
Ohhh My.. that is Gorgeous!
Ray
www.RayTomlinDesigns.com
| Re: New Flower [message #57138 is a reply to message #57104 ] Tue, 20 November 2012 09:35 UTC |
Sweet!
2mm sounds good.
| Re: New Flower [message #57174 is a reply to message #56991 ] Tue, 20 November 2012 19:00 UTC |
Thanks Ray, always appreciated.
Cheers Bart, am working with .8mm at the moment . . Time to change the stem design.
Piers
