Ring design
Ring design [message #57014] Sun, 18 November 2012 06:46 UTC Go to next message
avatar a3333326  is currently offline a3333326
I have created two rings, but I don't seem to be able to hook them together so that they look something from here-------" http://www.google.com/imgres?start=131&num=10&hl=zh- TW&tbm=isch&tbnid=DJj5TfuFTUZCFM:&imgrefurl=http ://queendom.ca/index.php%3Fmain_page%3Dproduct_info%26produc ts_id%3D96&docid=xODfKgf4A2keWM&imgurl=http://queend om.ca/images/35.jpg&w=309&h=310&ei=oIOoUKThEs_om AWPhYCQBw&zoom=1&iact=rc&dur=204&sig=1114021 64479877304836&page=5&tbnh=136&tbnw=138&ndsp =36&ved=1t:429,r:60,s:100,i:184&tx=92&ty=84& biw=1440&bih=687"
Is it possible that one of you experts help me out here by connecting the two rings I have made into something like that?
Thank you very much!
Regards,
Wade
  • Attachment: Ring 1.STL
    (Size: 1.04MB, Downloaded 70 time(s))
  • Attachment: Ring 2.STL
    (Size: 723.62KB, Downloaded 61 time(s))
Re: Ring design [message #57016 is a reply to message #57014 ] Sun, 18 November 2012 07:56 UTC Go to previous message
Here ya go Smile
You can probably do this in Solidworks. Load the first ring, then import the 2nd, select both rings/objects/layers and merge them into one. I followed this procedure with Accutrans3D.
[Updated on: Sun, 18 November 2012 07:57 UTC]
Previous Topic:Unable to convert file format and Scaling
Next Topic:Turn engraving into a hole
