Home » Community » It arrived! » Indra Iphone5 Case / 3D woven pattern
Indra Iphone5 Case / 3D woven pattern [message #55659] Fri, 19 October 2012 16:20 UTC Go to next message
avatar Genghis  is currently offline Genghis
Hi !
This is my entry for the Iphone 5 contest. This design was inspired by traditional indian pattern designs.
Unfortunately this doesn´t fit the Iphone, because I worked with the old (and wrong!) Iphone 5 template.
I am currently redesigning it with the right template and an Iphone 4s version as well.
Let me know what you think about it !
index.php?t=getfile&id=21905&private=0index.php?t=getfile&id=21904&private=0
http://www.shapeways.com/model/723057/d34cadff880963bf72e4df 182b5ae17b
[Updated on: Sun, 21 October 2012 14:58 UTC]
Re: Indra Iphone5 Case / 3D woven pattern [message #55663 is a reply to message #55659 ] Fri, 19 October 2012 17:30 UTC Go to previous messageGo to next message
avatar Wahtah  is currently offline Wahtah
I think it's really beautiful! Easily the best I've seen on shapeways... If only I had an iPhone 5 Cool
Update Indra Iphone5 Case / 3D woven pattern [message #56902 is a reply to message #55659 ] Thu, 15 November 2012 17:46 UTC Go to previous messageGo to next message
I received the update yesterday and I´m currently testing it on an iPhone 5.
It fits really good but I´m quite dissapointed by the polishing treatment. Indeed, only the inner faces are polished and not the outer ones Confused ...
index.php?t=getfile&id=22810&private=0index.php?t=getfile&id=22809&private=0
http://www.shapeways.com/model/723057/d34cadff880963bf72e4df 182b5ae17b?li=
[Updated on: Thu, 15 November 2012 17:47 UTC]
Re: Indra Iphone5 Case / 3D woven pattern [message #56905 is a reply to message #55659 ] Thu, 15 November 2012 18:19 UTC Go to previous messageGo to next message
I love the look and color, I'd email service about that polish. Doesn't look very polished to me either.
Re: Indra Iphone5 Case / 3D woven pattern [message #56956 is a reply to message #56905 ] Fri, 16 November 2012 16:28 UTC Go to previous messageGo to next message
Hey Genghis,
The design looks fantastic but perhaps a little thin. what is the wall thickness of the part?
Re: Indra Iphone5 Case / 3D woven pattern [message #56958 is a reply to message #56956 ] Fri, 16 November 2012 16:38 UTC Go to previous messageGo to next message
Hi Duann,
The thickness varies from 0,98 mm to 1,51 mm. I´m currently testing it and it is quite strong and flexible.
The case doesn´t slip but the corners are maybe to thin for an optimal protection.
Moreover, only the inner faces are polished and not the outer ones. Should I rotate the model before uploading ?
I´m designing a thicker version for iPhones 4 and 5 and will update it as soon as possible.
Thanks for help !
Re: Indra Iphone5 Case / 3D woven pattern [message #56959 is a reply to message #56958 ] Fri, 16 November 2012 16:48 UTC Go to previous message
Genghis wrote on Fri, 16 November 2012 16:38
Currently the position in the file doesn't effect the printing orientation, as the operator decides how they should print to produce the best results. That and the polishing is a post process done in a tumbler, so how it's oriented shouldn't effect the polish.
Previous Topic:Game Pieces Arrived!
Next Topic:New wireframe model
