| Inquiry quick (Bayonet)-lock for stereo plug/socket [message #56893] Thu, 15 November 2012 15:22 UTC |
I am trying to create a quick (bayonet)-lock
that connects a stereo plug & socket
(pls. find details within the attached .pdf file)
would like to ask you if my concept*
works with ABS/Vinyl or similar
rapid prototyping material?
would you ...
- use a different quick (bayonet)-lock
(please see sheet E)
- other than those material strenghts
that i defined within my project
(please see sheet F)
what should/can i do to optimise my project?
Any help is highly appreciated -
i look forward to hearing from you;
Best regards!
| Re: Inquiry quick (Bayonet)-lock for stereo plug/socket [message #57180 is a reply to message #56893 ] Tue, 20 November 2012 19:58 UTC |
I'm moving your question to the 3D modeling help needed section, hopefully someone can help you out there!
We don't print in vinyl or ABS, but perhaps White Strong & Flexible or Frosted Ultra Detail materials would work for this.
Community Manager | Shapeways
| Re: Inquiry quick (Bayonet)-lock for stereo plug/socket [message #57208 is a reply to message #56893 ] Tue, 20 November 2012 23:42 UTC |
... thanks a lot for your reply!
I actually created the .stl files already
(pls. see files attached)
in addition to my previous inquiry- :
i am not sure
- which/if any material is suitable
(there's a M8x1 screw's thread within both of the parts)
- if my construction will work in the "real world"
(or if there is a more convenient/easy solution)
I hope that someone may give me a hint/ post a link
for any similar application so that
i may alter/keep the concept.
