Home » Support » 3D Printing » Full color Sandstone "Not Printable"
Full color Sandstone "Not Printable" [message #56717] Mon, 12 November 2012 19:02 UTC Go to next message
avatar lacluna  is currently offline lacluna
Hello. I uploaded a model with the following dimensions: cm: 1.5 w x 6.8 d x 2.4 h / 4.30 cm³
This becomes available in many materials but not in full color sandstone. It IS available in regular sandstone. Isn't regular sandstone a different finish of the same material? Why is sandstone available and full color sandstone isn't? The walls are 2mm at its thinnest.
Please help.
Kaeyous Miniatures
http://www.shapeways.com/shops/Kaeyous
Re: Full color Sandstone "Not Printable" [message #56720 is a reply to message #56717 ] Mon, 12 November 2012 20:26 UTC Go to previous messageGo to next message
Did you upload a colored model, zipped together with the color map? If not, full color is not an option.
Re: Full color Sandstone "Not Printable" [message #56728 is a reply to message #56720 ] Mon, 12 November 2012 21:27 UTC Go to previous messageGo to next message
Thank you for your response. Finally I think I was able to upload it. Is there a way to preview the colors of your model before sending to print? my preview is still grayshaded (maybe that means I didn't upload it right?)
Kaeyous Miniatures
Re: Full color Sandstone "Not Printable" [message #56742 is a reply to message #56728 ] Tue, 13 November 2012 00:21 UTC Go to previous messageGo to next message
I am not meaning to sound rude, but what program did you create it in, and what format was the file you uploaded? It can get a little confusing until you get the technique down. 1 more question, did it have a texture, or just material colors assigned to faces?
One problem occurs when you put the model export, texture files in a folder, then zip the folder. Just select the export file and texture files, then zip the selected at one time. That zipped file is what you browse for at upload time.
If you want just attach the folder and post it here.
Re: Full color Sandstone "Not Printable" [message #56743 is a reply to message #56742 ] Tue, 13 November 2012 00:52 UTC Go to previous messageGo to next message
Hey Fredd. you don't sound rude at all.
-I am using maya and zbrush.
-I am using a texture file
-I export a both .wrl and .x3d files with zbrush.
-I can upload .x3d files only as the .wrl has sizing issues.
-Not Maya nor Zbrush import either .x3d or .wrl files and so I can't check if my file and UV's are exported correctly.
-Zbrush has a problem were it flips the UV's vertically and the map that is created when I export the .x3d files are flipped both vertical and horizontally. With all this flipping how can I know for sure if my texture is right?
- I just want to preview the texture in the file. When I do so, it will easy for me to flip if needed.
-I am not zipping a folder just the .x3d file and a .jpeg texture (2048x2048)
Last but no least... what is this .wrl and .x3d business? Why can't I just upload the globally accepted Obj which has UV information? oh well.
Is there a way to preview my textures in shapeways before I send it to print?
all your help is greatly appreciated.
Fredd wrote on Tue, 13 November 2012 00:21
Kaeyous Miniatures
Re: Full color Sandstone "Not Printable" [message #56745 is a reply to message #56743 ] Tue, 13 November 2012 01:22 UTC Go to previous messageGo to next message
You can upload your model to Shapeways at no charge for a preview. Can check to see it the textures are proper. If it does not show up textured you have a problem.
The x3D and wrl are used I guess because you can zip it and the texture together. x3D uses VMRL2
You could download Meshlab(free) to preview the texture and if the UV map is okay.
Below is a ugly test
http://images.shapeways.com/model/picture/674x501_742854_612 634_1350591440.jpg?key=c0fa3437b8a49ddf9ee91abbcf86b4c0
[Updated on: Tue, 13 November 2012 01:28 UTC]
Re: Full color Sandstone "Not Printable" [message #56747 is a reply to message #56745 ] Tue, 13 November 2012 02:21 UTC Go to previous messageGo to next message
avatar jamesnix  is currently offline jamesnix
You could get rid of the separate texture file by painting the jpeg texture file directly onto the model using spotlight in Zbrush. Then you will have a polypainted color model, and all you need to do then is export it as .wrl. Then zip just the .wrl file on its own and upload this zipped .wrl to shapeways. No need for any other file type. It will work then and you'll have your full color model.
[Updated on: Tue, 13 November 2012 02:28 UTC]
Re: Full color Sandstone "Not Printable" [message #56752 is a reply to message #56747 ] Tue, 13 November 2012 03:07 UTC Go to previous messageGo to next message
James that is totally intriguing technique. Could you post a small example file here I could experiment with please?
Re: Full color Sandstone "Not Printable" [message #56755 is a reply to message #56752 ] Tue, 13 November 2012 03:53 UTC Go to previous messageGo to next message
Hello. Attached is a test with a .x3d file exported from meshlab. While exporting, only the option "Wedge-TexCoord was selected".
The attachment is a zip file that contains the .x3d object and a a .jpeg texture. This is what I uploaded to shapeways and my preview does NOT have colors.
I appreciate all your help.
  • Attachment: test.zip
    (Size: 323.89KB, Downloaded 22 time(s))
Kaeyous Miniatures
Re: Full color Sandstone "Not Printable" [message #56758 is a reply to message #56755 ] Tue, 13 November 2012 05:29 UTC Go to previous messageGo to next message
Gah, I was snooping on google about textures and how they are applied in Z brush. You need to google these sources too. Gave me a bad headache. I know there are folks here that use Zbrush, just wait on more responses. or start a new thread, Zbush color exports.
I am still snooping.
This sounds like what you might need, confused me, http://www.shapeways.com/tutorials/fixing_maya_full_color_vr ml_with_magics
I opened the file with wordpad. It did not show a texture applied. Which is prolly why no textures are showing. Did not show a texture in Blender either. With meshlab if a texture shows,its been properly applied to a UV map. Read the tut above, will show you how to apply textures properly to the model. For help in Meshlab for export to x3D plus scaling stuff, post or PM me for help.
[Updated on: Tue, 13 November 2012 06:02 UTC]
Re: Full color Sandstone "Not Printable" [message #56785 is a reply to message #56717 ] Tue, 13 November 2012 16:47 UTC Go to previous messageGo to next message
Something is wrong with your export or something. Can you provide an obj? Looking at your x3d file (open it with notepad) there is no mention of texture file or test.jpg.
Re: Full color Sandstone "Not Printable" [message #56901 is a reply to message #56785 ] Thu, 15 November 2012 17:42 UTC Go to previous messageGo to next message
avatar MidnightCreations  is currently offline MidnightCreations
Why are materials ignored in Collada (DAE) files?
Re: Full color Sandstone "Not Printable" [message #56935 is a reply to message #56901 ] Fri, 16 November 2012 02:09 UTC Go to previous messageGo to next message
Midnight, what program are you using to export/import .dae?.
If it Sketchup, you might need to explode the model for the materials/uv mapping to work for a dae,
[Updated on: Fri, 16 November 2012 02:16 UTC]
Re: Full color Sandstone "Not Printable" [message #56936 is a reply to message #56935 ] Fri, 16 November 2012 02:46 UTC Go to previous messageGo to next message
Cinema 4D.
I've verified the XML includes materials and the exact same test file has colours when uploaded to Sculpteo.
The upload page lists "color uploads" as "WRL,X3D,X3DB, X3DV files" - no DAE listed - suggesting the format isn't checked for textures.
Re: Full color Sandstone "Not Printable" [message #56938 is a reply to message #56936 ] Fri, 16 November 2012 03:27 UTC Go to previous messageGo to next message
Yup, I agree that .dae does export textures and colors. Have changed many Skettchups collada into x3d files for color prints. The only thing I can figure out is the formats Shapeways does except can be opened up by notepad/wordpad to garner the information needed for printing in color. What is hilarious is that .dae supports scene data, none of the others when I export from Blender
Re: Full color Sandstone "Not Printable" [message #56941 is a reply to message #56717 ] Fri, 16 November 2012 04:35 UTC Go to previous messageGo to next message
Hello this is how I solved the problem
1. Export OBJ from maya
2. Import mesh in Meshlab http://meshlab.sourceforge.net/
3. Filter>Texture>Set Texture.
4. In the window that appears you need to type the name of your PNG (only) file that has to be located in the same directory as your mesh.
5. To check if your texture is applied correctly click Render>Show UV Tex Param. You should see a UV layout with your texture on it.
6. Export a .PLY file.
7. Create a New document.
8. Import the PLY file you just created. (You should see the texture on the object as you tumble around it).
9. Export a X3D File with ONLY the option "Wedge>Text Coord" selected
10. Zip the X3D file with the PNG texture
11. Upload the zip to shapeways.
YES, you NEED to export to PLY first and then to x3d because otherwise IT WON'T WORK in shapeways.
YES, it was a f..king darling to figure out.
Kaeyous Miniatures
Re: Full color Sandstone "Not Printable" [message #56950 is a reply to message #56717 ] Fri, 16 November 2012 14:24 UTC Go to previous messageGo to next message
More than one way to skin a cat as the saying goes. Just wondering, your vrml that had the wrong scale, did it's color show up? vrml defaults to meters as the units, so you'd have to scale your model to meters before exporting. Also try using Netfab for your conversions. It's specifically built for making printable models.
Re: Full color Sandstone "Not Printable" [message #56961 is a reply to message #56950 ] Fri, 16 November 2012 18:00 UTC Go to previous messageGo to next message
Sheesh, that is a big mess Lacluna. I guess a few curses were uttered. For curiousity's sake could you upload another test object with a uv map to see if I can simplify your work flow with Blender?
Congrats for persevering in your quest.Smile
Re: Full color Sandstone "Not Printable" [message #56985 is a reply to message #56950 ] Sat, 17 November 2012 02:54 UTC Go to previous messageGo to next message
The color didn't show up with the vmrl
Kaeyous Miniatures
Re: Full color Sandstone "Not Printable" [message #56998 is a reply to message #56985 ] Sat, 17 November 2012 17:18 UTC Go to previous messageGo to next message
I experimented with the darling project some more. Opened up a .obj file which had a UV mapped texture in Meshlab. Exported as a x3D. in the box that opened up , I un-clicked vertex color and vertex normal only. Zipped it and the texture, showed up in SW correct, although the faces that had different face materials did not show diffuse colors. For some odd reason when you use Meshlab to convert an obj to x3D,while ML might show face diffuse materials in in the render, does not show up at SW.
Continuing experiments and cursing .obj
Re: Full color Sandstone "Not Printable" [message #56999 is a reply to message #56998 ] Sat, 17 November 2012 18:58 UTC Go to previous message
so you had two different materials in the same object? both materials had the same diffuse texture? It is a weird software this meshlab. I had enough frustration I'm going to stick to my messy method.
Kaeyous Miniatures
Previous Topic:cannot print in ceramics
Next Topic:that printing final
