Home » Support » 3D Printing » holes size and moving parts
holes size and moving parts [message #56145] Mon, 29 October 2012 10:12 UTC Go to next message
avatar skoell  is currently offline skoell
hi everybody
(sorry for my english i'm french Confused )
I will wish to create a little pearl scorpion for a jewel and must do a hole.
http://www.skoell.fr/3dprint/scorp.jpg
the scorpion is about 5mm high ( leng 35mm width 25mm)
i see on the instructions holes must are 2mm diameter : this is big for a pearl hole.
I think also make moving parts, but if a see the instructions :
in exemple of an axle :
http://www.skoell.fr/3dprint/moving_part.jpg
moving axle is 1cm minimum
how the tiny 1cm car work ????
http://craphound.com/images/640x476_610080_470250_1340459113.jpg
What is the true minimum size for a hole ? and have i well understood the instructions ???
regards
Julien
Re: holes size and moving parts [message #56167 is a reply to message #56145 ] Mon, 29 October 2012 14:26 UTC Go to previous messageGo to next message
The dimensions required are entirely dependant upon which material you select.
This model is designed for FUD. http://shpws.me/lmmj Some of the walls are as thin as 0.7mm, and the gaps are only 0.1mm.
The cab and boom are both fully movable. The cab in particular uses almost exactly the same cross-section as your diagram shows.. just much, much smaller.
On each of the Material Pages you will find a "Clearance" value that tells you how much clearance you must allow to have movable parts.
Re: holes size and moving parts [message #56168 is a reply to message #56167 ] Mon, 29 October 2012 14:32 UTC Go to previous message
thank you
effectively i will find the good material for small objects
regards
Previous Topic:Stainless Steel - 3mm?
Next Topic:Understanding Shrinkage in Silver Casting
