| Model not facing front in shapeways image preview [message #55987] Fri, 26 October 2012 17:25 UTC |
Not sure what I am doing wrong but I made a few models in Sculptris and in Sculptris they are all facing the front but when I upload them to shapeways they are all facing upwards.
What am I missing?
http://i.imgur.com/fcZXw.png
http://i.imgur.com/SISLJ.png
| Re: Model not facing front in shapeways image preview [message #55992 is a reply to message #55987 ] Fri, 26 October 2012 17:59 UTC |
The issue here is that the "up" axis in 3d software is not uniformly defined.
For some it's Y, for others it's Z.
The easiest solution is to pre-rotate and update your model on the site.
Stijn
| Re: Model not facing front in shapeways image preview [message #55993 is a reply to message #55992 ] Fri, 26 October 2012 18:10 UTC |
| virtox wrote on Fri, 26 October 2012 17:59 | The issue here is that the "up" axis in 3d software is not uniformly defined.
Stijn
I actually tried to pre-rotate the model and the preview was unaffected, any ideas?
| Re: Model not facing front in shapeways image preview [message #55998 is a reply to message #55993 ] Fri, 26 October 2012 18:25 UTC |
Eh no, then I'm a bit stumped.
So regardless of orientation it ends up wrong in shapeways?
Can you see the change in rotation when you view the model in other software like (free) meshlab?
| Re: Model not facing front in shapeways image preview [message #55999 is a reply to message #55987 ] Fri, 26 October 2012 18:42 UTC |
Try orienting in Blender. I've seen some weird orientations out of Sculptris OBJ export.
