Home » Community » It arrived! » My first ring
My first ring [message #50352] Mon, 25 June 2012 19:10 UTC Go to next message
avatar Sapro  is currently offline Sapro
Hi everyone,
I just wanted to share a couple of pictures of my first creation with shapeways!
The final version is printed in silver glossy and polished.
index.php?t=getfile&id=17916&private=0
As it was expected it wasn't possible to polish inside the small groove but I think it gives a nice texture contrast.
index.php?t=getfile&id=17917&private=0
I have put some shot of the WSF prototype (with the gem intended for the silver ring) so you can see how good the details are in silver.
index.php?t=getfile&id=17918&private=0
The only issue is that shapeways left some of the building support in silver. So I will have to deal with these myself Crying or Very Sad
index.php?t=getfile&id=17919&private=0
What do you think? Any ideas how to improve even more the surface finish of small silver features?
I noticed a couple of "dirt' mark on the silver ring which were easily removed by hand.
index.php?t=getfile&id=17920&private=0
Re: My first ring [message #50604 is a reply to message #50352 ] Fri, 29 June 2012 16:33 UTC Go to previous messageGo to next message
Here we go the finished ring: polished and cleaned thoroughly and set with the gem! Let me know what you think. Smile
index.php?t=getfile&id=18097&private=0
index.php?t=getfile&id=18098&private=0
index.php?t=getfile&id=18099&private=0
Re: My first ring [message #55766 is a reply to message #50604 ] Mon, 22 October 2012 14:39 UTC Go to previous messageGo to next message
avatar MrFluffyThing  is currently offline MrFluffyThing
Amazing. Did you set the stone yourself? I'm looking at creating an Engagement ring sometime soon and would like to do this myself.
Re: My first ring [message #55770 is a reply to message #55766 ] Mon, 22 October 2012 14:57 UTC Go to previous messageGo to next message
Thanks MrFluffyThing!
Yes, I did set the stone myself by carefully spreading the prongs apart (they are little grooves in the tension prongs, see bottom pictures). Silver is very soft and bend easily so I had to be very careful.
This was also an engagement ring and it was a hit Very Happy
However, we had the exact same ring made in gold by a jeweler with a real diamond, and I think no one was keen on this type of setting. They all said that if it catches on something it can pull the prongs apart and loose the diamond. My opinion is that there is nothing to be caught on as the prong "blend" into the diamond. 4 months she wears it daily and it is still there!
Regards,
Sapro
Re: My first ring [message #55772 is a reply to message #55770 ] Mon, 22 October 2012 15:45 UTC Go to previous messageGo to next message
Later this year I'm going to attempt to design a simple silver ring with a setting for a Trillion cut CZ or Diamond stone. I'll keep your advice in mind. Thanks!
Re: My first ring [message #55910 is a reply to message #50352 ] Thu, 25 October 2012 09:40 UTC Go to previous messageGo to next message
wow! this is SO beautiful! Love the setting incorporated into the design!
Shapeways Community Manager
Re: My first ring [message #55925 is a reply to message #50352 ] Thu, 25 October 2012 16:43 UTC Go to previous messageGo to next message
I have a question.Im thinking of doing something similar. The silver base directly below the diamond with a little hole on it. Does the diamond sit on it or it is hovering over it? I never understood the purpose for the hole unless its meant to keep it in place.
- Sal G -
My Website
www.sgcustomsilver.com
Facebook Page
Re: My first ring [message #55929 is a reply to message #55925 ] Thu, 25 October 2012 17:06 UTC Go to previous messageGo to next message
The stone should sit above the ring in the ring shank. The hole is there so that the point of the stone is protected, and that the finger is protected from the point of the stone.
Bill Bedford
Re: My first ring [message #55931 is a reply to message #55929 ] Thu, 25 October 2012 17:47 UTC Go to previous messageGo to next message
Is there a website or store you recommend for good prices on CZ or natural black diamonds?
- Sal G -
My Website
Facebook Page
Re: My first ring [message #55932 is a reply to message #55931 ] Thu, 25 October 2012 17:53 UTC Go to previous messageGo to next message
I'd love to know the same. Did you buy local or online?
Re: My first ring [message #55934 is a reply to message #55932 ] Thu, 25 October 2012 18:02 UTC Go to previous messageGo to next message
I havent yet. Still looking for good options on clarity si1 or higher white diamonds or natural untreated black diamonds with no visible inclusions. I know two jewelers, Ill check with them and definitely post here if I find any good deals. Maybe ill start off with a lab grown while I search for the real one.
- Sal G -
My Website
Facebook Page
Re: My first ring [message #55936 is a reply to message #55932 ] Thu, 25 October 2012 18:11 UTC Go to previous messageGo to next message
To SG Designs: What BillBedford said is true protecting the diamond and the finger is one of the reason for this hole to be there. I will add two other reason for this particular design: it helps locating the stone when I snap it in and it also prevent the diamond from being "twisted" out. This kind of setting can be "unsafe" if there is somewhere to catch the stone (or the claws) as it can make it pop out.
For buying cz stone, this website offers very cheap ones: http://www.diamondcz.co.uk/
The one in the picture is not a cz diamond but a "simulant" from http://www.diamondnexus.com/loose-stones in the US. Apparently it is quite different than a CZ, but I am still not convinced by the difference in price...
Finally for real diamond, as I don't like the idea of a mined diamond (neither did she by the way Smile ), I bought a lab created diamond from Gemesis in the US to: http://gemesis.com/diamonds/. There I can really tell the difference Smile (but obvioulsy there is a huge difference in price to).
Regards,
Sapro
Re: My first ring [message #55937 is a reply to message #55936 ] Thu, 25 October 2012 18:14 UTC Go to previous messageGo to next message
SG Designs,
Proper lab grown diamond are real one (you can tell by their price to, even if they are a bit cheaper than mined one). You can find very good quality (near perfect in some case) which is very rare for mined one.
Anything else (simulant, cz, etc) are not the same thing as a real diamond.
[Updated on: Sat, 03 November 2012 22:02 UTC]
Re: My first ring [message #55983 is a reply to message #50352 ] Fri, 26 October 2012 16:04 UTC Go to previous message
I use GemSelect for real gems and RioGrande for lab grown and simulants.
Glenn
Previous Topic:Horseshoe crab
Next Topic:I'm really disappointed :(
