| Metal work for Armlet [message #55638] Fri, 19 October 2012 05:56 UTC |
I was just wondering if you could give me a quote to turn this into an actual armlet.
the material would need to be metal, preferably steel, that wont rust. Accurate to that style and be able to fit my over hand and be wearable with a sleeve as well.
Basically what that artist had done, down to the details in the bolts.
It also have to fit the dimensions of my hand and arm.
thanks,
Matthew
| Re: Metal work for Armlet [message #55657 is a reply to message #55638 ] Fri, 19 October 2012 14:40 UTC |
Could you please include some dimensions hand (ie. about how big the inside hole needs to be)? Do you want the bracelet to be two seperate parts that literally screw together or one part that slides over your wrist?
I could make this bracelet no problem and will get started right away, then I will adjust for your arm dimensions and give you a rendered image and a quote!
[Updated on: Fri, 19 October 2012 14:42 UTC]
