Home » Support » 3D Design » Why is this cube so exspensive
Why is this cube so exspensive [message #54969] Sat, 06 October 2012 18:06 UTC Go to next message
avatar Silverbeam  is currently offline Silverbeam
So I made a 2 inch cube with an inner wall of 1mm. why is my cube over 100.00$ dollars? I have lots of things uploaded and printed that would easily fill up several of the same sized cubes for less. So confused.
SEE ETSY SHOP: http://www.etsy.com/shop/Silverbeam
Re: Why is this cube so exspensive [message #54970 is a reply to message #54969 ] Sat, 06 October 2012 18:21 UTC Go to previous messageGo to next message
Maybe this will help and explain.
http://www.shapeways.com/tutorials/creating-hollow-objects
jacantdesign@gmail.com
Re: Why is this cube so exspensive [message #54972 is a reply to message #54970 ] Sat, 06 October 2012 18:39 UTC Go to previous messageGo to next message
I made it hollow, that's what I said about the 1mm thickness.
This is not my first model by far.
Re: Why is this cube so exspensive [message #54973 is a reply to message #54972 ] Sat, 06 October 2012 18:43 UTC Go to previous messageGo to next message
You have to make sure there is a hole or tunnel joining the inside to the outside . Otherwise Shapeways wil just ignore the inside and treat it as a solid
Re: Why is this cube so exspensive [message #54974 is a reply to message #54973 ] Sat, 06 October 2012 18:59 UTC Go to previous messageGo to next message
Are you sure? It doesn't seem that way on how it is worded, and not according to many of my models in the past. However I could be wrong and it is as you say, if so that would leave a lot to explore.
I will have to ask shapeways themselves to see what they say, unless you have already asked.
Re: Why is this cube so exspensive [message #54975 is a reply to message #54974 ] Sat, 06 October 2012 19:12 UTC Go to previous messageGo to next message
These two models are the same size and both are hollow. The first has a 1mm hole in the top, you can just see it.
http://www.shapeways.com/model/727711/f6744799f7da5da23d9b83 d80b16a342
http://www.shapeways.com/model/727712/62a498ba9f43c766ed88d3 4d15f6fc74
Big difference in the price.
Re: Why is this cube so exspensive [message #54976 is a reply to message #54975 ] Sat, 06 October 2012 19:14 UTC Go to previous messageGo to next message
If so then they need to be more explicit in the description.
Also I cant see those links.
Re: Why is this cube so exspensive [message #54979 is a reply to message #54976 ] Sat, 06 October 2012 19:27 UTC Go to previous messageGo to next message
Sorry I forgot to make them Display to the public
http://www.shapeways.com/search?q=jacant&sort=newest
Re: Why is this cube so exspensive [message #54996 is a reply to message #54979 ] Sun, 07 October 2012 03:33 UTC Go to previous message
If you have a volume inside a volume, Shapeways acts as a surface modeller. If you submerged the model in water, any surface that gets wet defines the volume. The inner volume you created is ignored by since it can not get wet. Now if you drilled a hole connecting the outer surface to the inner volumes surface,and the face normals are correctly aligned, you would have both the inner surface and outer surface connected providing a uniform surface that allows the printer to detect the hollowed out area. Plus the drainage hole needed once the model is printed. I experimented with boolean difference modifiers with a smaller cube inside a cube for the proper technique, using a cylinder as the drill object. Just experiment a little, if you need any help PM me.
Previous Topic:cheaper and smaller
Next Topic:Printing a surface made up of thin faces
