| Changing material in cart impossible when not logged in [message #54750] Tue, 02 October 2012 15:39 UTC |
I just simulated a customer:
I did not log in, but added some products to my cart.
Then I tried to change the material I wanted to order it in, but it did not work.
That means, that I can choose a material in the cart menu, but the site does not change it.
When you use the Lab-feature of adding sets you are dependent on
beeing able to change the material in your cart, because a customer
could like a material better than the default one.
It is also impossible to get back to your cart "settings" once you proceeded through login in the payment process.
-> There is no chance to change, when you had not been logged on.
It would be great if you fixed it rapidly
Yours, Marie
PS:
This problem appears no matter if you add sets or usual products, but always when you are not logged on.
I tested it several times and always reset my browser before doing so.
| Re: Changing material in cart impossible when not logged in [message #54753 is a reply to message #54750 ] Tue, 02 October 2012 17:30 UTC |
Which browser and Operating System are you using?
| Re: Changing material in cart impossible when not logged in [message #54794 is a reply to message #54753 ] Wed, 03 October 2012 15:05 UTC |
Great, that you already take care for it!
I use Safari 5.1.5 as a browser, my computer is running OS X (10.7.3) if that helps.
Thanks, Marie
