Home » Community » General Discussion » Transparent Resin material anytime soon?
Transparent Resin material anytime soon? [message #54706] Mon, 01 October 2012 18:08 UTC Go to next message
I would love to see Shapeways offer this material that one of your competitors has introduced... Anytime soon?
index.php?t=getfile&id=21021&private=0
Re: Transparent Resin material anytime soon? [message #54714 is a reply to message #54706 ] Mon, 01 October 2012 22:21 UTC Go to previous messageGo to next message
If you check the page that duck was taken from you will see that it was sanded and then varnished to get the transparency. You should be able to get a similar result with FUD. or transparent resin.
Bill Bedford
Re: Transparent Resin material anytime soon? [message #54715 is a reply to message #54714 ] Mon, 01 October 2012 23:13 UTC Go to previous messageGo to next message
I *highly* doubt you could get FUD to look like that. And transparent resin? Well, yes, that's what it's called. And since they do all the work it saves the customer having to do it.
"When you choose a technical finish for your transparent resin model, the support material (which is needed during the printing process) is first removed. Then your model is hardened under UV light and varnish is applied on all surfaces. This varnish is applied to your model to protect it from dust and discoloration. It makes a part transparent."
Re: Transparent Resin material anytime soon? [message #54731 is a reply to message #54715 ] Tue, 02 October 2012 08:59 UTC Go to previous message
lensman wrote on Mon, 01 October 2012 23:13
You can make FUD transparent by sanding the surface and varnishing it. You can test this for yourself by simply put the piece into water. Any clear liquid will 'fill in' the scratches on the surface so the piece will appear almost transparent
Shapeways don't do any of the post processing that other suppliers are will ing to do for a price.
Bill Bedford
Previous Topic:Is Makerbot replicator 2 comparable to WSF quality?
Next Topic:Shapeways Labs & Hacks: Better Tools for Your Shop
