Home » Support » 3D Printing » Best way to avoid print lines for this model
Best way to avoid print lines for this model [message #54422] Sun, 23 September 2012 14:21 UTC Go to next message
avatar ForTuchanka  is currently offline ForTuchanka
Hello, I've been working on a model and started to worry about print lines on the large "wings" for the model. What would be the best way to orient the model shown below (in a very quick mockup) to avoid obvious print lines on the surfaces? Would it be best to lay the design down flat or keep it vertical in the picture? I'll be using FUD as the material for the final design and the sphere in the center will be 1cm in diameter for reference. Thanks in advance for any help!
http://uploadnow.org/image/341746-example.jpeg
Re: Best way to avoid print lines for this model [message #54426 is a reply to message #54422 ] Sun, 23 September 2012 22:03 UTC Go to previous message
You can't control how the operator will place the part in the machine.
Previous Topic:iridescent materials
Next Topic:Help with Material selection for sculpture print.
