Home » Support » Bug Reporting & Site Feedback » Nearly right is not enough.
Nearly right is not enough. [message #54245] Wed, 19 September 2012 12:56 UTC Go to next message
avatar norm24  is currently offline norm24
Even if the end result is correct again should the subtotals to be correct.
index.php?t=getfile&id=20696&private=0
  • Attachment: Temp.jpg
    (Size: 12.62KB, Downloaded 164 time(s))
Re: Nearly right is not enough. [message #54299 is a reply to message #54245 ] Thu, 20 September 2012 16:50 UTC Go to previous messageGo to next message
Hi norm,
The subtotal is just for display for you. It is not a figure we use in accounting, we just display it on the invoice to make the invoice easy to read.
In accounting, we NEVER actually subtotal the amounts as this can lead to rounding errors.
We round once, at the end, so as not to overcharge you for the currency conversion.
If you think it would be clearer, I am happy to post the exact numbers too - but since it is your data, I am more than happy to do it via PM rather than on the public forum.
I hope this explains it!
Best,
Natalia
[Updated on: Thu, 20 September 2012 18:46 UTC]
Community Manager | Shapeways
Re: Nearly right is not enough. [message #54329 is a reply to message #54299 ] Fri, 21 September 2012 09:48 UTC Go to previous messageGo to next message
Hi Natalia
The invoice must always vote. Every single item has to be based on commercial principles to be rounded. These rounded values ​​are then added. For the commercial seller that is very important.
index.php?t=getfile&id=20748&private=0
Best,
Detlev
    (Size: 22.78KB, Downloaded 101 time(s))
Re: Nearly right is not enough. [message #54333 is a reply to message #54329 ] Fri, 21 September 2012 12:26 UTC Go to previous messageGo to next message
norm24 wrote on Fri, 21 September 2012 09:48
Detlev
Just to help avoid any confusion. I suspect that "Vote" here is a mistranslation of the German "Stimmen", which can mean either "be correct" or "vote", depending on context. "Be correct" would be the proper translation here.
Greetings
Dragoman
Re: Nearly right is not enough. [message #54446 is a reply to message #54333 ] Mon, 24 September 2012 14:34 UTC Go to previous message
Norm24, I PM'd you further details.
Best,
Natalia
Previous Topic:Prompting for second login on Parts Database
Next Topic:Pending Sales oddity
