iridescent materials
iridescent materials [message #53937] Wed, 12 September 2012 16:35 UTC Go to next message
avatar designprototype  is currently offline designprototype
Hi there,
Is there a material I could use that produces an iridescent effect?
I think (not 100% sure) a mixture of glass chemically bonded can create this effect by modifying the reflective properties ; or some type of acrylic when used as a paint.
I'd be very interested to see how you [shapeways] could advise/help me for my next project.
Thanks Smile
Re: iridescent materials [message #54130 is a reply to message #53937 ] Sun, 16 September 2012 20:00 UTC Go to previous messageGo to next message
I don't think any of the available materials could give an iridescent effect coming out of the factory. Though it should be possible to create such effects on glass or ceramic with surface treatments and aon any material with specialized paints. If you go to a crafts or art shop, they may be able to advise about iridiscent paint.
Greetings
Dragoman
Re: iridescent materials [message #54275 is a reply to message #54130 ] Thu, 20 September 2012 12:13 UTC Go to previous messageGo to next message
Thanks Dragoman - I'll see if I can get my hands on some specialized paint so I can give it a try.
Thanks once again Smile
Re: iridescent materials [message #54316 is a reply to message #53937 ] Thu, 20 September 2012 22:03 UTC Go to previous message
avatar VeryWetPaint  is currently offline VeryWetPaint
I used Jacquard Pearl-Ex pigments to add an iridescent effect to a 3D-printed model. I used the colors Interference Red, Interference Blue, and Interference Yellow. The pigment was applied dry, then bonded into the plastic by misting it with a plastic-welding solvent. This particular pigment is invisible under diffuse light, but the iridescent color magically appears in bright reflected light.
http://3.bp.blogspot.com/_MjEqr93DsvE/S8KoVKJ2P3I/AAAAAAAAAYw/GRAmJ6PIyX0/s1600/IMG_2535.JPG
This solvent-welding technique will only work with thermoplastic materials like PVC or ABS. Solvent-welding won't work with materials like frosted detail (a thermosetting resin) or sandstone (gypsum), but you could achieve a similar result by mixing the pearl pigments in transparent lacquer. I think the Pearl-Ex web page gives more suggestions.
In case you're curious, there are more pictures of my pigment-iridescent model on my blog here.
Previous Topic:This price can't be right?
Next Topic:Best way to avoid print lines for this model
