Home » Support » 3D Printing » Purple Strong & Flexible, extra thickness
Purple Strong & Flexible, extra thickness [message #53608] Tue, 04 September 2012 22:03 UTC Go to next message
avatar bmsleight  is currently offline bmsleight
Hi Shapeways,
Received my latest model in the post today - way ahead of schedule. They look fantastic...
http://i.imgur.com/oNJVbh.jpg
I have a question about accuracy, in particular Purple Strong & Flexible.
I had to sand down the round models, to fit. As I sanded them down - I revealed white plastic below. After sanding all the purple (die?), the models fit together perfectly. But the screw/tapping does not fit, as I can not sand the crevices.
See the next two photos....
http://i.imgur.com/Gl5Xjh.jpg
http://i.imgur.com/hpqmyh.jpg
The http://www.shapeways.com/materials/strong-flexible-design-gu idelines mention:-
Accuracy: ± 0.15mm, then ± 0.15% of longest Axis
How big is the coloured coating ?
Which colour in strong flexible does not have a covering - (guessing only white) ?
Brendan
Re: Purple Strong & Flexible, extra thickness [message #53628 is a reply to message #53608 ] Wed, 05 September 2012 13:34 UTC Go to previous messageGo to next message
The coloring isn't a coating, the whole part is dyed, but the dye only gets so deep. The other parts are stainless prints right? that has an accuracy of 2mm. So a combination of the 2 variances could lead to your fit issues.
Re: Purple Strong & Flexible, extra thickness [message #54036 is a reply to message #53628 ] Fri, 14 September 2012 19:09 UTC Go to previous message
Ok - thanks for the reply.
Previous Topic:big gears: what material to prevent buckling?
Next Topic:Strong and flexible plastic sublimate?
