Home » Community » Post Production Techniques » Levels of detail. Resolution
Levels of detail. Resolution [message #52568] Tue, 14 August 2012 08:48 UTC Go to next message
avatar maldini83  is currently offline maldini83
Hello all,
See if anyone here can help me out with this.
I need a level of detail in my design of about 10-50microns, that is to say 0.01mm, which is at least one order of magnitude higher than the ones I found here or any other 3D printing company (and 100x for metals, which is the material I actually want).
It would be awesome if someone here recommend me a research group, that can deal with these demanding conditions? Truly appreciate it!
Thank you
-Manu
Re: Levels of detail. Resolution [message #52652 is a reply to message #52568 ] Wed, 15 August 2012 19:30 UTC Go to previous messageGo to next message
avatar pdb  is currently offline pdb
Hello
You could try lost wax casting. Sorry i dont have time to go into the process but if you google it im sure theres a wiki
Rapidshape specialise in 3d printing for this process, keep in mind the print is lost when casting.
Slice Thickness: 10 / 25 / 50 /100 µm
Native Voxel* ~60µ, roundish harmonizer on click
http://www.rapidshape.de/s60-maxi/articles/rapid-3d-generati ve-prototyping-and-manufacturing-system-s60-maxi.html
Regards
PS 10 micron for a feature is a 'bit' small, even for the human eye
[Updated on: Wed, 15 August 2012 19:36 UTC]
boop
Re: Levels of detail. Resolution [message #52679 is a reply to message #52568 ] Wed, 15 August 2012 22:21 UTC Go to previous messageGo to next message
There are people who can do this level of detail, but I don't have details to hand. However this company may be able to help.
Bill Bedford
Re: Levels of detail. Resolution [message #52688 is a reply to message #52679 ] Thu, 16 August 2012 01:28 UTC Go to previous messageGo to next message
Hello BillBedford and pdb!
Thank you so much for your help!!
In any case, I was wrong about the level of detail I needed. It's in fact even higher: around 1micron. Yes, I know, it's going to be difficult but let's see if somebody comes up with a useful idea! (Very likely not in 3D printing).
So far, best option I have is go to arc machining shop...but I'd like to see some other approaches (even better if they're cheaper!!).
-Maldini
Re: Levels of detail. Resolution [message #53664 is a reply to message #52688 ] Wed, 05 September 2012 22:27 UTC Go to previous message
avatar timday  is currently offline timday
For fabicating things on micron scales, I'd have thought you'd need to be looking into photolithography (see also wpedia). While the process is normally associated with relatively flat silicon chips (albeit with multiple layers), there's also a whole world of microelectromechanical systems (MEMS) at similar scales; actually that page lists some other fabrication technologies besides lithography.
Previous Topic:material suggestions
Next Topic:shapeway's model to studio quality scale model
