Home » Community » It arrived! » Redi Cube and Fadi Cube by OSKAR
Redi Cube and Fadi Cube by OSKAR [message #5338] Tue, 21 July 2009 15:59 UTC Go to next message
Hi Shapeways fans,
Redi Cube and Fadi Cube are both twisty puzzles, like the Rubik's Cube. Here, the pieces turn around the cube corners. These puzzles are an attempt to use other than conventional slices to make a twisty puzzle. At first sight, it looks impossible to twist this puzzle at all. But the pieces go over and under eachother to make it possible.
Watch the YouTube clips:
http://www.youtube.com/watch?v=cjfMzA1u3vM
http://www.youtube.com/watch?v=C1WfiZpeXC8
Buy the puzzles:
http://www.shapeways.com/model/40561/redi_cube.html
http://www.shapeways.com/model/40559/fadi_cube.html
Look at the photos below.
Enjoy!
Oskar
index.php?t=getfile&id=1013&private=0
index.php?t=getfile&id=1009&private=0
index.php?t=getfile&id=1010&private=0
index.php?t=getfile&id=1011&private=0
index.php?t=getfile&id=1012&private=0
[Updated on: Sun, 03 October 2010 15:24 UTC]
Re: Redi Cube and Fadi Cube [message #5341 is a reply to message #5338 ] Tue, 21 July 2009 16:43 UTC Go to previous messageGo to next message
I really like these designs, because they retain cubical symmetry. Also, at first glace they appear to be standard Rubik's Cubes but no standard Rubik's cube moves are possible!
I would think the one drawback to WSF for making these puzzles would be its somewhat rough finished texture. Have you experimented with any sanding to smooth out the action?
[Updated on: Tue, 21 July 2009 16:47 UTC]
Re: Redi Cube and Fadi Cube [message #5343 is a reply to message #5341 ] Tue, 21 July 2009 17:06 UTC Go to previous messageGo to next message
Hi George,
You will be surprised about the smoothness of the movement of these puzzles when I show them to you next time we meet.
There is absolutely no need to do any sanding. The turning of the first few moves is a bit rough. Then the pieces have sanded each other sufficiently to have perfectly smooth turning.
Oskar
Re: Redi Cube and Fadi Cube [message #5348 is a reply to message #5343 ] Tue, 21 July 2009 19:19 UTC Go to previous messageGo to next message
Cool! I would love to try some of them out. Its hard to tell how smooth they are from your videos.
Re: Redi Cube and Fadi Cube [message #5353 is a reply to message #5338 ] Wed, 22 July 2009 00:24 UTC Go to previous messageGo to next message
avatar Nshortino  is currently offline Nshortino
All of the puzzles like these that I keep seeing on Shapeways never stop amazing me. I understand the mechanics of a Rubik's Cube, but each time a new puzzle comes up on here I stare at it wondering how in the world it could possibly work.
Nice work on both puzzles. Are the colors painted on or are they stickers? And have you experimented with scrambling and solving them yet?
I'd be interested to know how difficult they are in comparison to a traditional Rubik's Cube.I have a few friends who can solve them pretty quickly, so I might be interested in some of these new designs as gifts to keep them busy for a while.
Re: Redi Cube and Fadi Cube [message #5354 is a reply to message #5353 ] Wed, 22 July 2009 02:22 UTC Go to previous messageGo to next message
Hi Nicholas,
These are stickers. I order all my stickers from Dragan "Dr. Sticker" Tutic. He offers high quality custom-made stickers for a very attractive price.
http://www.dr-sticker.com/about---contact.php
Eh, ..., so far I have only scrambled them, taken apart and reassembled.
Some of them are much harder, some are easier. What is important is that they all are very different from a traditional Rubik's. So your friends will be baffled, as they can't use any of the moves they learned for their Rubik's Cube.
Oskar
Re: Redi Cube and Fadi Cube [message #5372 is a reply to message #5354 ] Fri, 24 July 2009 05:40 UTC Go to previous message
avatar MaxSMoke777  is currently offline MaxSMoke777
Instead of using stickers, have you considering making a slot into each face, allowing a small square to be slotted into place? Then you could paint the squares separately with acrylic to achieve the same solid color, then slot it into place. It's alot more crafty and elegant then stickers. And by keeping each piece separate well painting, you don't have to put in alot of careful brush work. You could even use metallic or iridescent spray paints to give each square a nifty finish stickers can't match.
Alternatively, another idea might be to forgo the traditional simple colors and instead emboss the sides of the cube with famous paintings, faces, or some other kind of simple and recognizable picture. That way, instead of just colors, each face could be a work of art on to itself.
For example:
If you were making just a regular Rubix Cube, make a thin square box with a few thousand faces and use a function like 3D Studio's Displace to extrude the box. Then carefully divide the box into 9 even pieces, shrink a bit so there's a gap between each piece, and affix each piece to the face of one of Cube elements.
Or you could attach end caps to each piece, much the same way the Gear Ball was made into the Gear Heart. You might remember the Darth Maul head that was also a Rubix Cube? You could attach sectioned geometry to each face, making a puzzle that is also a statue on to itself when completed.
Previous Topic:Some polyhedra
Next Topic:Canny Uncube by OSKAR
