Home » Community » General Discussion » How to avoid warping on flat FUD parts?
How to avoid warping on flat FUD parts? [message #52193] Wed, 01 August 2012 13:02 UTC Go to next message
avatar RolandR  is currently offline RolandR
http://i.imgur.com/bKK8a.jpg
As you can see, this part is quite heavily warped. Of the six I ordered, some are almost flat while others look like this or even worse.
The flat part is about 0.5mm thick with an 1.5mm frame around it (you can see the rectangle frame in the image).
How do I avoid warping? I considered the following options:
  • Make the part thicker. This will make the model less realistic.
  • Fill the area inside the frame. Not an option as I will add a metallic weight there.
  • Add a support beam in the middle. This, again, will make the model less realistic.
  • Print the part sideways. Not really an option as one side would then suffer from surface damage caused by support wax.
Re: How to avoid warping on flat FUD parts? [message #52194 is a reply to message #52193 ] Wed, 01 August 2012 13:17 UTC Go to previous messageGo to next message
What about a removable support beam? Something that could easily be snipped off, that runs the length of the item. Another option is warming it up in some warm water, and try to flatten warped parts.
Re: How to avoid warping on flat FUD parts? [message #52195 is a reply to message #52193 ] Wed, 01 August 2012 13:19 UTC Go to previous messageGo to next message
You can rescue the model by pouring some hot water over it.
Re: How to avoid warping on flat FUD parts? [message #52199 is a reply to message #52195 ] Wed, 01 August 2012 13:20 UTC Go to previous messageGo to next message
Thanks for the hot water tip!
Will this fix the part permanently?
Re: How to avoid warping on flat FUD parts? [message #52200 is a reply to message #52193 ] Wed, 01 August 2012 13:26 UTC Go to previous messageGo to next message
It should do.
Re: How to avoid warping on flat FUD parts? [message #52243 is a reply to message #52200 ] Thu, 02 August 2012 16:31 UTC Go to previous message
avatar Phxman  is currently offline Phxman
This would happen to the prototype too, if it were not for the underframe.
Even injection molded items have a representation of an underframe, to keep the model square and rigid.
[Updated on: Thu, 02 August 2012 16:32 UTC]
Previous Topic:Need help with next step for mass producing an item...
Next Topic:Answer a question in the Quirky forums
