Home » Community » Work in progress » Ceramic Bracelet Links
Ceramic Bracelet Links [message #52105] Mon, 30 July 2012 18:53 UTC Go to next message
So has anyone tried making links for a bracelet in ceramic yet? So far what i've seen larger smooth designs print best with Ceramic... Do you think there will be problems or issues with simple designs? Has anyone tried designs printed with small holes? I dont mind cleaning up the parts with post production.
Any thoughts?
www.RayTomlinDesigns.com
Re: Ceramic Bracelet Links [message #52106 is a reply to message #52105 ] Mon, 30 July 2012 19:33 UTC Go to previous messageGo to next message
Maybe i should give some technical information...
I plan on using "Gucci Pins" which have a screw on one end. the bearal of the pin is 1.28mm thick, and the screw heads are 3mm wide. Therefore the pin holes need to be fairly small probably 1.35mm wide
Also these pins only go up to 18mm long, with the possibility of getting longer but not likely....
If this project is successful then i plan on making a watch to match it. Very Happy
Ray
Re: Ceramic Bracelet Links [message #52110 is a reply to message #52105 ] Mon, 30 July 2012 21:35 UTC Go to previous messageGo to next message
avatar Mezmera  is currently offline Mezmera
I don't have experience with that, but won't the bounding box minimum size and 'no interlocking parts' make it quite difficult, if not impossible to print at the moment?
I'm thinking about creating ceramic wearables as well, and one concern I have is the unglazed part of the model. I'm not sure if the unglazed surface will be too coarse for wearing directly on skin. Did you plan to keep the unglazed part between the links?
Re: Ceramic Bracelet Links [message #52112 is a reply to message #52110 ] Mon, 30 July 2012 22:05 UTC Go to previous messageGo to next message
I didn't see a minimum size for the bounding box. i did see a maximum..
Ray
Re: Ceramic Bracelet Links [message #52115 is a reply to message #52112 ] Mon, 30 July 2012 22:38 UTC Go to previous messageGo to next message
From http://www.shapeways.com/materials/ceramics-design-guideline s;
Min Bounding Box:
x+y+z≥120mm
Long time no see, how ya doin? Smile
Re: Ceramic Bracelet Links [message #52120 is a reply to message #52115 ] Mon, 30 July 2012 23:38 UTC Go to previous message
Trying to get enough time to get models made, but I have a few things i'm working on. Especially since I just got a new laptop! Very Happy
Ray
Previous Topic:working mini bow?
Next Topic:Double-o #5 – "Wire Ring"
