Home » Support » 3D Printing » Embossed detail
Embossed detail [message #51605] Fri, 20 July 2012 06:46 UTC Go to next message
avatar PlainOrb  is currently offline PlainOrb
In the tutorial of stainless steel polishing, it says embossed detail at least 0.8 mm. Does it mean 0.8 mm thickness and 0.8mm width ?
Plain Orb
Re: Embossed detail [message #51626 is a reply to message #51605 ] Fri, 20 July 2012 19:59 UTC Go to previous messageGo to next message
I want to say both. I believe it's referring to the height of the emboss, so by the rules it would have to at least be as wide as it is thick. But I'll see if Nancy can clarify this for us.
Edit: I was wrong, it is the thickness of the font. But you still need to maintain a 1:1 thickness and width
P.S. if you could include a link to the page, it will help in finding what you are looking at faster.
[Updated on: Fri, 20 July 2012 20:29 UTC]
Re: Embossed detail [message #51650 is a reply to message #51605 ] Sat, 21 July 2012 13:55 UTC Go to previous messageGo to next message
Thanks for the quick reply. Here is the link to the page I'm looking at: http://www.shapeways.com/design-rules/stainless-steel-polish ing
so, both height and width of font should be at least 0.8 mm ?
Plain Orb
Re: Embossed detail [message #51653 is a reply to message #51650 ] Sat, 21 July 2012 16:57 UTC Go to previous messageGo to next message
A good example in my Check Rope Ring - the print in the main image was further polished by me using a dremel type rotary tool - The checker pattern has 1mm squares, the rope starts at ~0.8mm at the base thinning to nothing at the top but is still proud of the main structure of the ring.
The second image shows how the ring arrived;
http://images1.sw-cdn.net/model/picture/640x476_180408_113946_1338413386.jpg
If you can, blend the edges of the embossing into the main structure of the model and model the raised parts as rounded, with maybe a 0.25mm radius corner to get good results.
Re: Embossed detail [message #51811 is a reply to message #51653 ] Wed, 25 July 2012 05:07 UTC Go to previous messageGo to next message
I use Arial bold 15 pt , which brings width between 0.7mm ~ 1mm and height at 1mm. I'm not able to make round corner even at 0.2mm radius. Will the polishing make it round a little ?
Plain Orb
Re: Embossed detail [message #51831 is a reply to message #51811 ] Wed, 25 July 2012 13:36 UTC Go to previous message
Polishing should round any exposed sharp corners.
Previous Topic:Suitable for Sandstone
Next Topic:High Detail Print (WD or FD?)
