Yet another manifold issue
Yet another manifold issue [message #5137] Mon, 06 July 2009 02:43 UTC Go to next message
avatar Ushanka  is currently offline Ushanka
Howdy, all, I've got a model of the apple of discord. However, the text etched on the apple makes the model non-manifold. Here is the interior view of one of the letters:
http://i168.photobucket.com/albums/u164/Ushanka/kallistiapple2Snap00-1.png
I've been trying to fix it in MeshLab, but I'm not exactly sure how to proceed. The .stl file is attached.
[Updated on: Mon, 06 July 2009 02:43 UTC]
Re: Yet another manifold issue [message #5139 is a reply to message #5137 ] Mon, 06 July 2009 07:03 UTC Go to previous messageGo to next message
Hi Ushanka;
The issue is that the letters are not manifold. The back surface of them that intersect with the apple are not closed. And they are rather jagged as well.
In addition, the bottom of you stem is not closed either.
I am becoming a big fan of Meshlab, but can't tell you how to fix it with that quite yet.
Walking you through fixing this in Blender would be a Tutorial all its own. So I'll just explain the basic gist.
the stem I just closed by extruding the edges to a point, and then removing the doubles.
The letters, I separated from the model making them there own mesh. Moved them to a separate layer. Then looking down (Num 7 in blender) I deleted all the verts beyond the front faces of the letters. I.e. Reduced the letters to only they're 2D faces. And then extruded them along the normals. I also hollowed out your apple as it would cost $330+ USD to print as a solid object.
Re: Yet another manifold issue [message #5140 is a reply to message #5137 ] Mon, 06 July 2009 07:29 UTC Go to previous messageGo to next message
Thanks! Can you attach the not-hollowed version as well?
Re: Yet another manifold issue [message #5141 is a reply to message #5140 ] Mon, 06 July 2009 11:00 UTC Go to previous message
Sure....
Here ya go mate.
Very Happy
Previous Topic:Hollow object more expensive?
Next Topic:Minimum wall thickness vs cylinder diameter
