Filtering small objects from STL files
Filtering small objects from STL files [message #50968] Sat, 07 July 2012 11:45 UTC Go to next message
avatar decapod  is currently offline decapod
There seems to be some filtering out of small objects based on their volume on upload to shapeways.
(At least for STL which I use)
Here is a test I did reducing a 1mm cube to 0.7, 0.49 and 0.34 sides
Then repeat but leaving the vertical as 1mm
Then added a cylinder and repeated the process.
16 objects should appear.
index.php?t=getfile&id=18291&private=0
The smallest cube and the smallest 3 cylinders were removed during the upload (which gives me an approximate idea of what the volume used to filter out it.
The problem is that all of the 16 objects are valid for printing with FUD, no dimension is less than 0.35mm
You can only get around this by combining manifold objects to increase the volume - someting to be aware of.
I may be able to write a small script for my modelling tool to identify these objects but others may hit this problem too.
Re: Filtering small objects from STL files [message #50970 is a reply to message #50968 ] Sat, 07 July 2012 12:45 UTC Go to previous messageGo to next message
I remember I had this problem, too, some thin parts missing after upload.
Greetings
Karl Heinz
[Updated on: Sat, 07 July 2012 12:45 UTC]
Re: Filtering small objects from STL files [message #50976 is a reply to message #50968 ] Sat, 07 July 2012 17:23 UTC Go to previous messageGo to next message
To rule out thin parts, I tested this out with some chain maille, 0.3mm wire thickness (220 rings/shells) - it uploaded fine with no missing parts, this maybe that the rings are interlaced, so in effect there's 'one' model within the file. I've also noticed in the past that colour models have a limit to 15 parts regardless of the image map size.
Something is definately amiss.
Re: Filtering small objects from STL files [message #51072 is a reply to message #50968 ] Mon, 09 July 2012 14:42 UTC Go to previous messageGo to next message
Not sure why that'd be happening, I'll email some people to see if they know why.
Re: Filtering small objects from STL files [message #51096 is a reply to message #50968 ] Tue, 10 July 2012 00:19 UTC Go to previous messageGo to next message
avatar tsw  is currently offline tsw
Hi Paul,
Can you provide the model id or attach the file for us to look at?
Re: Filtering small objects from STL files [message #51110 is a reply to message #51096 ] Tue, 10 July 2012 13:30 UTC Go to previous messageGo to next message
Here's the test stl file I uploaded...
  • Attachment: test.STL
    (Size: 85.00KB, Downloaded 34 time(s))
Re: Filtering small objects from STL files [message #51162 is a reply to message #51110 ] Wed, 11 July 2012 18:46 UTC Go to previous messageGo to next message
Thanks for attaching the file.
To answer your original question, yes we do have filtering logic to remove shells with very small volumes. This filtering is in place to remove "ghost" shells which are sometimes left over from processing a file and can cause problems for printing.
We have the minimum volume set at 0.1 cubic millimeters. Any parts that are smaller than that will be removed.
We'll make sure that this information is added to the materials options page.
Re: Filtering small objects from STL files [message #51168 is a reply to message #51162 ] Wed, 11 July 2012 18:59 UTC Go to previous messageGo to next message
Hiya tsw,
Quick question relating to "less than 0.1 cubic mm' parts - does this apply to single watertight meshes that intersect a larger part to form 'detail' that could comply with FUD design rules?
Re: Filtering small objects from STL files [message #51182 is a reply to message #51168 ] Wed, 11 July 2012 21:00 UTC Go to previous messageGo to next message
Hey Paul,
Parts that intersect should get merged into a single part. As long as the volume of the combined part is greater than the minimum, it would be safe from getting removed.
So for the example you gave, the small parts to form detail should be fine.
Hope that helps.
Re: Filtering small objects from STL files [message #51213 is a reply to message #51182 ] Thu, 12 July 2012 06:36 UTC Go to previous messageGo to next message
Actually that's a no - I had small "shell" objects intersecting a large object and they were removed on uploading.
The trick is to just mke them larger and intersect more.
Thanks for the info on the volume, I can now write a script to check all my parts before uploading now.
Re: Filtering small objects from STL files [message #51219 is a reply to message #51182 ] Thu, 12 July 2012 10:06 UTC Go to previous messageGo to next message
tsw wrote on Wed, 11 July 2012 21:00
Hey Paul,
Hope that helps.
Unfortunately, they do get removed (but there is a workaround with NetFabb Cloud Service)
See this example;
A 10mm ball with 0.2mm diameter by 0.15mm studs, the studs intersect the ball by 0.025mm, individually the studs each have a volume of about 0.09426cc.
Here's what the ball with studs looks like (I've made the studs red so that the distribution can be seen)
http://www.stop4stuff.com/shapeways/images/10mm-dia-ball-with-studs.JPG
A stud with measurements in NetFabb.
http://www.stop4stuff.com/shapeways/images/stud-for-10mm-ball.JPG
The model after Shapeways 'treatment', the studs have been removed - model page http://shpws.me/apVl
http://images1.sw-cdn.net/model/picture/640x476_630737_490577_1342086060.jpg
The model after using NetFabb Cloud Service to merge the meshes before uploading to Shapeways - model page http://shpws.me/apVC
http://images1.sw-cdn.net/model/picture/640x476_630747_490595_1342086927.jpg
Model file attached.
Re: Filtering small objects from STL files [message #51251 is a reply to message #51219 ] Thu, 12 July 2012 22:44 UTC Go to previous messageGo to next message
avatar xjohnnywang  is currently offline xjohnnywang
You are correct, and there seems to be a threshold size where the small part, even if intersecting a larger part, will disappear. I had tested on a small cube of 0.34 mm and was fine, but a smaller cube of size 0.2 mm got removed.
We will look into this.
Re: Filtering small objects from STL files [message #51255 is a reply to message #51251 ] Thu, 12 July 2012 23:12 UTC Go to previous messageGo to next message
your man/woman tsw already dais anything smaller than 0.1cc gets removed - please can we have some consistency?
Re: Filtering small objects from STL files [message #51256 is a reply to message #51255 ] Fri, 13 July 2012 00:51 UTC Go to previous messageGo to next message
Clarification:
What was meant was that individual shells smaller than 0.1 cc gets removed.
Shells that are smaller than 0.1 cc, but intersects a larger part should stay because merging is suppose to take place. Since this case isn't always true, we will look into it.
The example given by xjohnnywang was meant to be a cube with 0.34mm per side (so smaller than 0.1 cc).
Re: Filtering small objects from STL files [message #51260 is a reply to message #51256 ] Fri, 13 July 2012 04:26 UTC Go to previous messageGo to next message
Either something has changed, or there is something more complex happening here...
This model http://shpws.me/3Rrl has wheels/axles are independent, loose shells and are 0.01cm3.. that's 1/10th of the size mentioned above!
Theyand are NOT removed from the model when it's uploaded, and they print just fine, even rotate properly in the final model.
Re: Filtering small objects from STL files [message #51264 is a reply to message #51260 ] Fri, 13 July 2012 06:12 UTC Go to previous message
Actually, I got my sums wrong, those little studs are about 0.09426 cubic mm Embarassed
They still fall into the realms of being printable in FUD though.
@Stony, The axles on your railcar mover are 'interlaced' with the rest of the model, perhaps that's the difference?
Previous Topic:Bad 3d printed layers
Next Topic:Recyclable material
