Ceramics DodBox
Ceramics DodBox [message #50571] Fri, 29 June 2012 06:37 UTC Go to next message
Shapeways Crew
The Ceramics DodBox arrived!
It's made of two identical parts that form a dodecahedron similar to the Truncated Sphere D12.
This is the bigger model I ever printed, and the walls are really thick!
index.php?t=getfile&id=18069&private=0
Please check the video.
I am very pleased with it, in particular the ways the box can be closed. The colors are great too!
But I am wondering if I should remove the pegs and holes at the bottom:
- I though they would be big enough the allow the bottom to be glazed but this is not the case.
- they are used to stack the boxes, but I am unsure this is really useful.
index.php?t=getfile&id=18070&private=0
Perhaps a flat bottom would be more aesthetical.
What do you think?
  • Attachment: IMG_3612.JPG
    (Size: 163.95KB, Downloaded 548 time(s))
  • Attachment: IMG_3613.JPG
    (Size: 133.91KB, Downloaded 536 time(s))
Re: Ceramics DodBox [message #50573 is a reply to message #50571 ] Fri, 29 June 2012 06:47 UTC Go to previous messageGo to next message
Oohw is it Magic Friday again? Smile
Love them! Very cute! Nod
I would recommend to really avoid these sharp edges in ceramics, it reduces the look and feel a lot.
Then again in this model it is almost a must for the best fit/seal Wink
Again kudos Wink
Stijn
Re: Ceramics DodBox [message #50614 is a reply to message #50573 ] Fri, 29 June 2012 18:00 UTC Go to previous messageGo to next message
Shapeways Crew
Laughing
Yes, I wanted to have softer edges, but my software refused to work properly (first it was difficult to select the appropriate edges and second the result was very very bad).
What software could I use to bevel the edges properly?
Re: Ceramics DodBox [message #50654 is a reply to message #50614 ] Sat, 30 June 2012 20:13 UTC Go to previous messageGo to next message
Shapeways Crew
By going back and forth from my software to Meshlab, I got a 2mm radius on each edge.
I also reduced the thickness to 7.5mm instead of 10mm to get an acceptable cost (the internal volume is still the same), and I removed the holes and pegs of the bottom.
Et voilà: the Ceramics DodBox v2!
I will have to wait a little bit before I order it though, because I already have another order on its way (and I am out of money also Smile)
Re: Ceramics DodBox [message #50723 is a reply to message #50573 ] Mon, 02 July 2012 23:12 UTC Go to previous messageGo to next message
avatar opresco  is currently offline opresco
Hi Stijn,
Other than aesthetics (sorry to disappoint you on this), do you think
the models below will print /glaze/fire OK? How about lettering?; do you think it'll show on the printed piece?
Sake Cup #7
http://shpws.me/8D8l
Sake Finger Cup #7a
http://shpws.me/8HUs
Sake Finger Cup #7
http://shpws.me/8HSB
cascador
Re: Ceramics DodBox [message #50724 is a reply to message #50571 ] Mon, 02 July 2012 23:16 UTC Go to previous messageGo to next message
Very nice!
I think a flat glazed bottom will look better; but, will they do it?
cascador
Re: Ceramics DodBox [message #50731 is a reply to message #50724 ] Tue, 03 July 2012 05:53 UTC Go to previous messageGo to next message
Shapeways Crew
Thanks Opresco, I know you like polyhedra too... Smile
If I make it flat, the bottom will remain unglazed. The reason why I added the pegs was to have all the bottom glazed except the pegs, but it failed: I guess the pegs were not high enough. The inside of the holes are glazed though. But I think i prefer having the bottom of the box unglazed and keep the original and simple shape.
To answer your questions, please check the Design Rules:
Quote:
Min Detail:
for embossed details: keep width of detail greater than 2mm, or 36pt font (Arial)
for engraved text: keep width of detail greater than 3mm, or 60pt font (Arial)
and
Quote:
Tip #1: Rule of Thumb: If this structure was made of wet sand, would it break?
Just like Stainless Steel, there's a part in the process of making ceramics model where the model is fragile and brittle. It's basically like wet sand. So when building your structures, think--can my structure be made with wet sand?
I don't know if your text is big enough to print, and I am afraid that your ring will not support the weight of the dodecahedron or at least will not easily stand vertically during the glazing phase...
It would be nice to give it a try but that's a pity Glazed Ceramics is so expensive: it is difficult to make prototypes in those conditions...
Re: Ceramics DodBox [message #50753 is a reply to message #50731 ] Tue, 03 July 2012 16:25 UTC Go to previous messageGo to next message
index.php?t=getfile&id=18175&private=0
Thanks Magic,
I gave this a try (see link below), and the ring (4 mm at the thinnest) managed to support it).
Espresso & Sake Finger Cup
http://shpws.me/8fH4
I am using the same ring specs for the entire series of finger cups.
If /when I get them printed I'll post the results in "It Arrived".
Sake Finger Cup #7
Thanks for directing me to Design Rules. But, as you very well know, without breaking them we'll end up with bulky, very expensive prototypes Wink
[Updated on: Tue, 03 July 2012 17:36 UTC]
cascador
Re: Ceramics DodBox [message #50785 is a reply to message #50753 ] Wed, 04 July 2012 05:54 UTC Go to previous messageGo to next message
Shapeways Crew
Ahaha! For sure we need cascadors to take risks on the design side!
I confess I wouldn't have bet the ring could support the cup!
That's very surprising what 3D printing can do with Ceramics, as long as you believe it can be done...
What is the thickness of your Espresso & Sake Finger Cup?
PS: Great dice by the way.
Re: Ceramics DodBox [message #50837 is a reply to message #50785 ] Thu, 05 July 2012 04:52 UTC Go to previous messageGo to next message
In the actual stl file:
Cup wall thickness: 2.8 mm
Dish: 2.5 mm
Ring Inner Diameter: 21 mm
In the ceramics printed piece:
Cup wall thickness: 4 mm
Dish: 2.7 mm
Ring Inner Diameter: 20 mm
(no wonder the ring would not fit my finger; the stl file is updated now with 24mm ID in the ring)
I know, It's the glaze that screws up the dimensions; I have an idea for a design in ceramics where the dimensions of the printed piece are critical (it has to snap fit an existing object).
Based upon my findings above, I'm going to give it a try soon, when I get rich Smile.
Some of the dice in the pics are my concept for a new class in dice: "Spring Loaded Dice" Smile See links below.
Spring-loaded Icodie
http://shpws.me/6nrb
Spring-loaded 30-sided die
http://shpws.me/6nqb
Spring-loaded die
http://shpws.me/6nAa
Spring-Loaded Dodedie
http://shpws.me/a3lO
Thanks again,
cascador
Re: Ceramics DodBox [message #51158 is a reply to message #50837 ] Wed, 11 July 2012 18:13 UTC Go to previous messageGo to next message
Shapeways Crew
Next time I will probably try a smaller version (3mm thickness).
See this post for more information.
Re: Ceramics DodBox [message #51198 is a reply to message #51158 ] Thu, 12 July 2012 00:13 UTC Go to previous message
“The only way to discover the limits of the possible
is to go beyond them into the impossible.”
Arthur C. Clarke
[Updated on: Thu, 12 July 2012 12:07 UTC]
cascador
Previous Topic:A.N. Vase and A.N. Key Holder
Next Topic:soap dishes and soap form
