The Stranzer is the ultimate in anti-'Con technology. An entire armory in one weapon, the Stranzer is suited for combat at any distance. You can fight up close, hacking and slashing through 'Cons. You can blast them at mid-range with the Stranzer's built-in blaster, and enemies far away get a nasty surprise when a knife flies right into their optic sensors.
Stranzer Weapon Kit on Shapeways
This weapon kit consists of:
-- 1x Stranzer Blaster
-- 2x Stranzer Scimitars (Left/Right)
-- 1x Stranzer Combat Knife
The Stranzer Weapons are all designed to be used with one another, and can be combined with each other. When all the Stranzer weapons are combined, the result is the Stranzer Bow:
The Stranzer Weapons are all able to store on Cliffjumper. While the Combat Knife is designed to be stowed on his left leg in robot mode, the entire Stranzer Bow can be attached to his back as well:
The Stranzer weapon kit is designed to work with the Transformer Prime (RID) Cliffjumper action figure. The weapon can also be used by any other figure with access to 5mm hand-holes.
Of course, being made for Cliffjumper, it does also fit on his vehicle mode:
