| Bushings from 1/2" to M12 (12mm) [message #50130] Wed, 20 June 2012 21:16 UTC |
LOOK BELOW
[Updated on: Thu, 21 June 2012 18:02 UTC]
| Re: Bushings from 1/2" to M12 (12mm) [message #50152 is a reply to message #50130 ] Thu, 21 June 2012 17:15 UTC |
Hi again.
I read on the material page that I cant have such thin walls on the metal printing, so I have a revised idea. Instead of sleeving from the inside, I can sleeve from the outside with metal.
The inside I can either fill the gap with liquid polyurethane and use the M12 bolt to get it smooth. Or I could use a very simple 3d printing in strong and flexible polished.
The revised idea is to get the sleeves on the outside of the flanges on this bushing:
http://www.qa1.net/qa1_motorsports/drag-and-street/suspensio n-accessories/shock-mount-accessories/bearing-kits.html
It's a tad complicated to explain, so I will mspaint it.
If someone wants to quote me the design (personal use). I could also use an "internal" sleeve with OD: 13mm, ID. 12MM and length: 25mm.
OUTER DIAMETRE 20mm for the one in the picture
Attachment: bushing.png
(Size: 404.68KB, Downloaded 41 time(s))
[Updated on: Thu, 21 June 2012 17:32 UTC]
| Re: Bushings from 1/2" to M12 (12mm) [message #50169 is a reply to message #50152 ] Thu, 21 June 2012 23:18 UTC |
PM Sent
Inspire through Design, Create Solutions, Deliver on Promise
| Re: Bushings from 1/2" to M12 (12mm) [message #50237 is a reply to message #50130 ] Fri, 22 June 2012 21:15 UTC |
Hi all, pfeiffer stylez made the model.
I also managed to make it my self quite easy. After 10 mins I could do the basics of sketchup. Did some mistakes on the size, but this has inpired me to learn more.
I've sent a beer to pfeiffer stylez as thanx.
This is my model
The model from pfeiffer stylez is smoother (and the correct size). Anyhow, I have what I need now Thanks again, pfeiffer stylez!
Bier zeit!
