Home » Support » 3D Applications » Maya 2009 for Linux - How to Export
Maya 2009 for Linux - How to Export [message #49921] Sat, 16 June 2012 17:43 UTC Go to next message
avatar WebmistressM  is currently offline WebmistressM
As of now, Im using Maya 2009 for creating my jewelry for Shapeways. I have been reading this tutorial to help me find out how to prepare a model for proper sizing.
http://www.shapeways.com/tutorials/exporting-from-maya-with- collada-3dprinting
Mentioned here, the writer cites that I need to get the Collada plugin from this URL:
http://www.feelingsoftware.com/content/view/55/72/lang,en/
Since Feeling Software is no longer, the link above does not work. Through searching, I have been able to find the collada.mll file for Windows Maya, but not the .so extension for Linux. The closest I would get to getting the Linux compatible library is compiling it from here:
http://code.google.com/p/opencollada/source/browse/#svn%2Ftr unk
Sadly, compiling from source is what Im weak on. It was suggested in other threads to export as an OBJ and then use Meshlab.
http://www.squidoo.com/shapeways-with-maya-and-meshlab
Given that Linux is almost never supported on anything and my compile-from-source skills are so rusty, it seems better for me to look towards the Meshlab way.
Are there any other Linux Maya users that might have similar experiences when it came to figuring the best way to export their designs from Maya?
Re: Maya 2009 for Linux - How to Export [message #50250 is a reply to message #49921 ] Sat, 23 June 2012 01:24 UTC Go to previous messageGo to next message
Sorry.. perhaps someone else here on the forum can help. I use *nix many times a day at work, but it's always command line stuff.. never in Xwindows.
Another possible place to check.. there should be support forum for Maya.. I'd pose your question there as well.
Re: Maya 2009 for Linux - How to Export [message #50255 is a reply to message #50250 ] Sat, 23 June 2012 04:06 UTC Go to previous messageGo to next message
Yeah. I am hoping too. Been patient all these days (besides, Shouldnt really bump topics up). Ill see what meshlab turns up for now.
Re: Maya 2009 for Linux - How to Export [message #52813 is a reply to message #50255 ] Sun, 19 August 2012 02:00 UTC Go to previous messageGo to next message
avatar tkaap  is currently offline tkaap
Take a look at the mayaExportSTL MEL script. That should work regardless of operating system. That's what I use, and it works fairly well if you don't need colors.
http://www.creativecrash.com/maya/downloads/scripts-plugins/ utility-external/export/c/mayaexportstl
-T
Re: Maya 2009 for Linux - How to Export [message #52927 is a reply to message #52813 ] Tue, 21 August 2012 04:00 UTC Go to previous messageGo to next message
Thanks. I shall try this. Should I still use a tool to make sure the measurements (scale/proportion) are correct?
Re: Maya 2009 for Linux - How to Export [message #52928 is a reply to message #52927 ] Tue, 21 August 2012 04:02 UTC Go to previous message
I usually double-check the STL files in netfabb before uploading them, but so far the sizes have all been accurate.
-T
Previous Topic:Viscam mesh
Next Topic:Field of view
