| Low poly Escher lizard pendant [message #49061] Tue, 29 May 2012 12:19 UTC |
This is my first print in metal, and I'm really pleased with the result.
I modified the original to allow a cord to be passed through... only the design makes it difficult to insert the intended way (through the two holes on the reverse of the head).
A side effect of this was that I was forced to pass the cord through the larger hole and the neck - the result being that the little guy hangs in a more Gecko-like manner... which I think works out for the better.
Admittedly the cord was on the thick side - 2mm leather - a much thinner cord might work through the intended holes. While waiting for the print to arrive, I've figured out a way to implement larger holes, which I'll try in a future print.
One last point - the SS version does indeed tessellate with the WSF version... but only just... I'd need to take a file to the limbs of the plastic variant to make it fit properly... oh well, I quite like it as a stand alone piece...
Shown here in Antique Bronze Matte.
Attachment: lzrd_sm.jpg
(Size: 162.29KB, Downloaded 247 time(s))
mygadgetlife.blogspot.co.uk
| Re: Low poly Escher lizard pendant [message #49063 is a reply to message #49061 ] Tue, 29 May 2012 13:43 UTC |
Very nice! Does it still lie flat on a table (cord removed)? I would like to see a photo of the back ...
[Updated on: Tue, 29 May 2012 13:46 UTC]
| Re: Low poly Escher lizard pendant [message #49125 is a reply to message #49061 ] Tue, 29 May 2012 21:19 UTC |
Hey thanks!
You can see from the photos how the reverse is designed... the holes are really too small to accept a fat cord (being my first metal print, I was highly aware of printing tolerances), but I got around the issue by threading as shown. I've re-done the reverse in a way which allows greater flexibility I think... I'll order a new print of this soon!
Alas, it doesn't lie flat - but the WSF version is only flat due to the loop being extremely small to the point of being almost unusable.
Attachment: IMGP0107.JPG
(Size: 196.40KB, Downloaded 206 time(s))
Attachment: IMGP0102.JPG
(Size: 56.94KB, Downloaded 205 time(s))
| Re: Low poly Escher lizard pendant [message #49126 is a reply to message #49125 ] Tue, 29 May 2012 21:27 UTC |
Thanks! It does hang nicely as a pendant. Having a flat back and hanging nicely may not be possible. It would be cool if you could wear several of them and have them tesselate!
[Updated on: Tue, 29 May 2012 21:28 UTC]
