| Finishing WSF material with plastic casting? [message #48550] Wed, 16 May 2012 22:56 UTC |
Anyone tried finishing WSF with SmoothCast 300 or other similar casting plastics? I want to try because it has a fast cure time (20 minutes) but I've heard it gets real hot when it reacts (up to 100c) and the WSF page says it has a heat resistance of up to 80c, was wondering if anyone has tried it or recommends for/against it.
| Re: Finishing WSF material with plastic casting? [message #48831 is a reply to message #48550 ] Thu, 24 May 2012 00:08 UTC |
i have limited experience with fast cast. but i believe it might depend on how much resin you are using.
small amount = less heat generated
(i cant see any info in the tech sheet on it. so it probably varies too much between different jobs)
i imagine that if you got something with a slower curing time the heat wouldnt be as much of an issue.
any chance you could upload a picture ?
or expected volume?
regards
boop
