Home » Support » 3D Applications » How do I boolean together subtools in Zbrush?
How do I boolean together subtools in Zbrush? [message #48521] Wed, 16 May 2012 09:47 UTC Go to next message
avatar Relaxis  is currently offline Relaxis
Hi guys,
I use Poser to get my base mesh and then I export to Zbrush, use subtool extraction and then usually I go to Subtool master and merge all, deleting the old subtools. Then I export the merged mesh as an stl in 3d print exporter.
SO far I've had mixed results, half of my models have no problems after being fixed in netfabb and others cannot be fixed - "surface not orientable" in netfabb and shapeways errors produce "mixed winding triangles" errors.
After one of the moderators looked at my model that I was having problems with he said that there were holes in the face from the teeth and that all the clothing meshes were seperate from the base mesh and they needed to be booleaned together - little help?
Re: How do I boolean together subtools in Zbrush? [message #48522 is a reply to message #48521 ] Wed, 16 May 2012 09:53 UTC Go to previous messageGo to next message
Link here to the thread - http://www.shapeways.com/forum/index.php?t=rview&goto=48 490#msg_48490
Re: How do I boolean together subtools in Zbrush? [message #48681 is a reply to message #48521 ] Sat, 19 May 2012 13:22 UTC Go to previous messageGo to next message
In ZBrush with both sub tools visible, go to the SubTool menu and click on ReMesh All. Make sure X, Y and Z are not selected and the ReMesh Resolution bar is set higher. This will definitely make your model water tight.
[Updated on: Sat, 19 May 2012 13:24 UTC]
- Sal G -
My Website
www.sgcustomsilver.com
Facebook Page
Re: How do I boolean together subtools in Zbrush? [message #48983 is a reply to message #48521 ] Sat, 26 May 2012 21:22 UTC Go to previous message
If you have Zbrush 4 you might want to use the DynaMesh feature, that works even better.
- Sal G -
My Website
Facebook Page
Previous Topic:Any ZBrush users out there ?
Next Topic:Trouble with balance point testing (Softimage)
