Pop-up earring holder/display for Flextest
Pop-up earring holder/display for Flextest [message #48151] Wed, 09 May 2012 22:38 UTC
avatar CharGyse  is currently offline CharGyse
Hey guys, what do you make of this?
[Flextest] Pop-up Jewellery Display & Case Bangle
index.php?t=getfile&id=16735&private=0
I have no idea if it will work or how well it would work, but I figured it wouldn't hurt if I prototyped it up and entered it Smile
"Designed for the Shapeways 3D Print Flex-Contest, this item comes in two parts - a bangle "case" and a jewellery display. They are printed together but are detachable.
The bangle has an internal diameter of 65mm to fit small wrists like mine, and features a flower shape with four "petals" and a central "style" with "stigma" stopper on the end. The petals have circular loops on the end to squeeze the "stigma" through, holding the flower closed.
The large criss-cross patterned stand or jewellery display is built with hooked earrings in mind, but can potentially also be used to hold cufflinks, and possibly bangles, bracelets and necklaces.
It may not be suitable for heavy jewellery, but has not yet been tested.
The idea is that when not in use, the display can be squished up small enough to fit into the closed flower on the bangle.
For use in the home and also out at craft fairs and car boot sales."
Enjoys spending 98 hours a week learning, making and designing stuff. The picture of me as a kid is... pretty much what you're dealing with.
Previous Topic:Need to create a .wrl file from a 3DS file
Next Topic:Protecting FCS kept in water
