Home » Support » 3D Design » Pendant w/ Thread - Need Help
Pendant w/ Thread - Need Help [message #46943] Fri, 13 April 2012 14:24 UTC Go to next message
avatar 6516440  is currently offline 6516440
What im doing:
So I am designing a pendant to give to my girl friend. It will be the first thing I print on shapeways. The idea is the pendant will hold a message on a piece of paper wrapped around a pin inside. The pendant will be two parts and made of sterling silver. My CAD skills are more then adequate to produce the pendant, Im using solidworks.
The problem:
Im not sure what specs I should give the screw thread. So i wanted anyone's advice on the pitch, clearance and size of the thread. The nominal diameter is 4mm. The pendant is pictured both with a cross section and with out. I have read the material data sheet, but the minimum detail of 0.6mm isn't as much clarification as i would like.
Any help or feedback would be appreciated as im looking forward to doing more projects through shapeways.
  • Attachment: Pendant.JPG
    (Size: 21.04KB, Downloaded 58 time(s))
  • Attachment: Capture.JPG
    (Size: 32.77KB, Downloaded 48 time(s))
  • Attachment: 1.JPG
    (Size: 45.93KB, Downloaded 38 time(s))
  • Attachment: 2.JPG
    (Size: 44.30KB, Downloaded 37 time(s))
Re: Pendant w/ Thread - Need Help [message #47488 is a reply to message #46943 ] Wed, 25 April 2012 19:02 UTC Go to previous messageGo to next message
avatar bradykineticcuriosities  is currently offline bradykineticcuriosities
You could model the thread easily, but your tolerancing will vary depending on how it is oriented in the build.
This is just an idea, but what about having a pin lock? I couldn't find a picture of an example, so I uploaded a quick concept.
index.php?t=getfile&id=16367&private=0
The transverse pin is inserted and turned clockwise to lock - it would be ideal to have some sort of detent so it would stay locked.
  • Attachment: Pin lock.jpg
    (Size: 80.16KB, Downloaded 135 time(s))
A good head and a good heart are always a formidable combination.
Re: Pendant w/ Thread - Need Help [message #47509 is a reply to message #47488 ] Thu, 26 April 2012 06:13 UTC Go to previous messageGo to next message
Thanks for the response, Unfortunatly i submitted my order a day ago. I will post some pics of what I did.
As for your idea, i do like edison sockets, i should have thought of that.
i left a gap of 0.1mm between the threads, i hope thats enough for the tolerances.
[Updated on: Thu, 26 April 2012 06:14 UTC]
Re: Pendant w/ Thread - Need Help [message #47526 is a reply to message #47509 ] Thu, 26 April 2012 11:17 UTC Go to previous message
If it doesn't work out you can get a tap and die and clean up the threads - assuming you modeled a standard thread that is.
Let us know how it goes!
Previous Topic:object rotation/orientation question
Next Topic:Advice: Material/finish for car badge
