need help choosing material
need help choosing material [message #46733] Tue, 10 April 2012 15:48 UTC Go to next message
avatar pdb  is currently offline pdb
hey guys
what is the best material for a mount for a phone. it has multiple parts. joints that allow 360 rotation. and will eventually be adapted to fit generic tripods
ideally it must be very rigid and strong (i dont want the phone bouncing around every where when you take a picture). im thinking alumide but am worried at the brittle-ness of it.
the example is 1.5mm dia. over 20mm length will most likely break
i plan to use rods with diameters of 4.1mm ..... is it still as brittle at these tolerances ?
i know the image might be a bit confusing but its only to show the basic structure .......i need to decide on a material before i can work out the mechanics.
and what gap you have to leave between moveable parts?
i can seem to find it anywhere? even on the materials page
regards
index.php?t=getfile&id=16021&private=0
  • Attachment: k.JPG
    (Size: 21.24KB, Downloaded 209 time(s))
boop
Re: need help choosing material [message #47435 is a reply to message #46733 ] Tue, 24 April 2012 21:07 UTC Go to previous messageGo to next message
avatar bradykineticcuriosities  is currently offline bradykineticcuriosities
Hey pdb,
I'm also working on something with moving parts - I haven't seen any spec on movable parts for WSF or Aluminide, but I plan on shooting for a .2 mm clearance on the radius for my first test piece in aluminide.
As for the brittleness, it might be best to do a small test print and see what it can withstand - this is what I plan on doing for my smallest parts (3.8mm thickness).
Couple of points on your good looking model. Your "cross" mount is basically two unsupported wires - it might be stronger if you put webbing between them, like a swiss cheese I-beam, thicker where the cross meets... Razz
Gussets on the sides wouldn't hurt - these don't have to be big.
I've got other thoughts, but you have a great concept there!
Will you be driving the gears with anything?
www.bradykineticcuriosities.com A good head and a good heart are always a formidable combination.
Re: need help choosing material [message #47436 is a reply to message #47435 ] Tue, 24 April 2012 21:20 UTC Go to previous messageGo to next message
Before you go with 0.2mm clearance, check out the Tutorials (linked to down at the bottom of every page), in particular, look at Material Design Rules and Advanced: Designing mechanical parts, part I, Advanced: Designing mechanical parts, part II as well as Advanced: Design rules & Accuracy, part III
There's some good info Rolling Eyes
Re: need help choosing material [message #47437 is a reply to message #47436 ] Tue, 24 April 2012 22:12 UTC Go to previous message
This was perfect - the point about using "bumps" to maintain a tight fit but still allow for clearance was inspired.
Previous Topic:the egg cup
Next Topic:Rose Bracelet
