Home » Support » 3D Design » object rotation/orientation question
object rotation/orientation question [message #47360] Mon, 23 April 2012 06:01 UTC Go to next message
avatar captainharlock  is currently offline captainharlock
When saving STL files from Solidworks, the objects show up as rotated onto their side in Shapeways. I.E. the top plane in SW faces forward in the preview thumbnail generated for that model on Shapeways, so the model appears to be standing on end.
My question is does that have any relation to how it is oriented in the printer, or do they orient the object at time of print for best results or best support structure? A lot of the materials have a 'grain' and it may matter which way the object is rotated in relation to the built up layers of material for best results, especially when making objects out of stainless where the resulting item is desired to be used as is without painting or sanding. When done right the stainless has a natural cast look, but if you catch the grain in the wrong direction it can be funny.
This problem can be worked around in Solidworks by re-defining the default view orientations and planes, or by rotating the saved STL file after the conversion but I'm wondering if I should bother in the first place, other than to fix the thumbnail view of an item if I am going to be offering it in a store.
-Mike
Re: object rotation/orientation question [message #47487 is a reply to message #47360 ] Wed, 25 April 2012 18:21 UTC Go to previous message
avatar bradykineticcuriosities  is currently offline bradykineticcuriosities
It has been my experience that the orientation shown on the preview is not the build orientation - each build is packaged for maximum efficiency, and this means some models get rotated to fit.
I'm all for specifying a build orientation, but it would most likely come at a higher cost (less build efficiency) or a longer lead time (waiting for more models to fill in the build envelope).
As far as the preview orientation goes, Z is treated as up for most 3D printing.
A good head and a good heart are always a formidable combination.
Previous Topic:Self-Intersecting faces?
Next Topic:Pendant w/ Thread - Need Help
