Polygon limit
Polygon limit [message #46875] Thu, 12 April 2012 18:23 UTC Go to next message
avatar extruder  is currently offline extruder
Hi Smile
Is there a max number of polys per model for upload to print?
I'm creating a piece in zbrush, and its pushing 4 million polys.
Thanks in advance!
[Updated on: Thu, 12 April 2012 18:24 UTC]
Re: Polygon limit [message #46877 is a reply to message #46875 ] Thu, 12 April 2012 18:42 UTC Go to previous messageGo to next message
avatar TomZ  is currently offline TomZ
Yes, the limit is one million triangles (not polygons) per model uploaded to Shapeways. If you absolutely need more than that you can use this trick: http://www.shapeways.com/blog/archives/564-How-To-3D-Print-H igh-Polygon-Models-with-Shapeways.html
Re: Polygon limit [message #46889 is a reply to message #46875 ] Thu, 12 April 2012 20:42 UTC Go to previous messageGo to next message
avatar aaronzhu1985  is currently offline aaronzhu1985
there is a plugin that's included in zbrush called declaymation master. look it up on youtube, you won't be dispointed
Re: Polygon limit [message #46895 is a reply to message #46877 ] Thu, 12 April 2012 22:02 UTC Go to previous messageGo to next message
thanks, i'll try that out.
but i don't understand:
"the volume of the cube needs to be the same actual material volume, no bounding box."
what does that mean?
Re: Polygon limit [message #114433 is a reply to message #46895 ] Thu, 23 April 2015 23:46 UTC Go to previous messageGo to next message
avatar rhyging5  is currently offline rhyging5
hello everybody, it is still one million of triangles the current limitation? thks in advance
Re: Polygon limit [message #114443 is a reply to message #114433 ] Fri, 24 April 2015 07:08 UTC Go to previous messageGo to next message
Yes, you still see this on the upload screen. There have been sporadic reports suggesting that this is not a hard limit as far as the site software is concerned - but consider (a) automatic fixing may need to create additional triangles (b) automatic tests may time out if the file is too big (c) in the end it probably depends on which material you want to use - each printer and associated software will have its own limitations. (My wild guess is that the "sandstone" printer would be the first to drop off the list as it has the additional burden of color information.)
Re: Polygon limit [message #114474 is a reply to message #114443 ] Fri, 24 April 2015 15:20 UTC Go to previous message
thanks a lot! you clarify me all the doubts ;) but not agree at all that is a good limit. Two million would be more close to perfection ;)
Previous Topic:Models with Vertex colors plus textures for color sandstone printing
Next Topic:Orange peel texture on gold-plated brass
