"Triangles with mixed winding order found" error
"Triangles with mixed winding order found" error [message #46146] Thu, 29 March 2012 16:51 UTC Go to next message
avatar SophieKahn  is currently offline SophieKahn
Hi everyone,
I was recently attempting to upload an stl and got the "Triangles with mixed winding order found" error. I'm a pretty experienced Netfabb Pro user and tried all the fixes with no success (self-intersections removed, piece booleaned into a single shell, etc).
Has anyone else ever run into this? Even the support staff member who emailed me said she didn't know what it meant!
I saw one other post on this subject, but that was a beginner with a problematic mesh, and mine looks clean as far as I can tell...
http://www.scannerworksny.com
Re: "Triangles with mixed winding order found" error [message #46169 is a reply to message #46146 ] Thu, 29 March 2012 23:36 UTC Go to previous messageGo to next message
In Netfabb, did you apply the "Flipped Triangles" repair?
That's usually the cause of this message.
Re: "Triangles with mixed winding order found" error [message #46173 is a reply to message #46169 ] Fri, 30 March 2012 02:16 UTC Go to previous messageGo to next message
I did already, I'm afraid. Netfabb is showing 0 triangles with invalid orientation. Thanks for the suggestion though, good to know it could be a normals issue...
Re: "Triangles with mixed winding order found" error [message #46207 is a reply to message #46173 ] Fri, 30 March 2012 19:09 UTC Go to previous messageGo to next message
avatar paulburkittgray  is currently offline paulburkittgray
I had this issue with a model a while ago, always got the "triangles with mixed winding order" message, despite the model showing as fine in Netfabb and watertight in Accutrans. The really confusing thing was that the faulty model was a slight modification of one that went through without problems.
In the end I discovered a hole hidden inside the model, and when I fixed it manually the model uploaded successfully. The hole had been auto-fixed by Netfabb, and was present and didn't cause any problems on the original model, so I'm not entirely sure why this solved the problem, but it did.
So, possibly there is a hole somewhere that is mysteriously causing the problem despite it apparently being fixed by Netfabb?
[Updated on: Fri, 30 March 2012 19:10 UTC]
Re: "Triangles with mixed winding order found" error [message #46209 is a reply to message #46146 ] Fri, 30 March 2012 19:55 UTC Go to previous messageGo to next message
avatar tempusr88898_d560e03d74a  is currently offline tempusr88898_d560e03d74a
One thing that Netfabb on Shapeways does is it also unions all the pieces that are touching.
This is so you don't get charged for the overlapping volume.
Netfabb basic doesn't have that function, so that might be why you get some extra error messages from Shapeways.
Sounds like you figured out what your issue was, so that's good. Smile
Re: "Triangles with mixed winding order found" error [message #46211 is a reply to message #46209 ] Fri, 30 March 2012 20:25 UTC Go to previous messageGo to next message
Mary.Huang wrote on Fri, 30 March 2012 19:55
Netfabb Basic doesn't union shells, but Netfabb Cloud service - http://cloud.netfabb.com/ - does so very neatly and is well worth using at any time before uploading - Wink
DIdn't the OP's issue used to be called a 'winding check error'? - I used to get that quite regular attempting to upload a .dae file before I figured out to convert to and check everything as an stl file for non-colour models.
Re: "Triangles with mixed winding order found" error [message #46215 is a reply to message #46211 ] Fri, 30 March 2012 21:14 UTC Go to previous messageGo to next message
Thanks for all the thoughts, everyone!
I am actually using Netfabb Pro already. I'm still stuck unfortunately. I may just have to go back to an earlier version of the file and see if Shapeways will accept that.
Re: "Triangles with mixed winding order found" error [message #47184 is a reply to message #46215 ] Wed, 18 April 2012 19:46 UTC Go to previous messageGo to next message
avatar nervoussystem  is currently offline nervoussystem
I had this same error today and fixed it by running a boolean union on the finished part in Netfabb Pro
this operation removes self-intersecting portions
http://n-e-r-v-o-u-s.com
Re: "Triangles with mixed winding order found" error [message #47186 is a reply to message #47184 ] Wed, 18 April 2012 19:49 UTC Go to previous messageGo to next message
Cool, I'll try that, thanks for the tip Smile
Re: "Triangles with mixed winding order found" error [message #47832 is a reply to message #47186 ] Thu, 03 May 2012 16:59 UTC Go to previous message
avatar tonysw  is currently offline tonysw
Sophie, are you still having issues with the file? If so, can you send me the file to look at and analyze? Since we are always trying to improve the acceptance rate of uploads, this will also give us another data point on error files.
Previous Topic:does anyone actually post in the 'my collections' sticky?
Next Topic:WSF and the Material Pages
