Home » Support » 3D Applications » From 3ds....
From 3ds.... [message #45488] Wed, 14 March 2012 11:45 UTC Go to next message
avatar James3DS  is currently offline James3DS
When I export my model from 3ds Max, the model is always faceted in the shapeways preview no matter how much I smooth it.
Could anybody tell me if I can smooth it in the Shapeways editor or how if they know any appropriate settings prior to export from 3ds Max.
James Abell.
Re: From 3ds.... [message #45522 is a reply to message #45488 ] Wed, 14 March 2012 22:45 UTC Go to previous messageGo to next message
Hi
I use Autocad I don't know if any of the commands are the same in 3DS. Same company (autodesk).
Try 'facetres' on the command line. change parameters to 10.
This site has a reference to 3DS.
http://solidwild.posterous.com/cad-guide-to-stl-export-for-3 d-printing
jacantdesign@gmail.com
Re: From 3ds.... [message #45609 is a reply to message #45488 ] Sat, 17 March 2012 03:08 UTC Go to previous messageGo to next message
Smoothing is a effect that alters a models surface during render. For nicer images.
A 3D printers takes into account the positions of every vertice, thus corresponding faces, and tries to form the model from the info in the file.(Mathematical position in 3d space) If you want a smoother object to be printed, subdivide it to the max, smaller faces,shorter edges lead to a smoother looking result. Excuse, the max comment was not a pun.Smile.
Consistant faces is why a manifold mesh is so important to the printer. Its a dumb machine, after all
Re: From 3ds.... [message #45773 is a reply to message #45488 ] Tue, 20 March 2012 23:06 UTC Go to previous message
Ok,
Thanks, I will subdivide more and try that.
I want the 3d print when I get it, to use as a model for a silicon mould or similar and then make copies in resin.
I think I can smooth out the facets when I cast it and then can recast it.
Thanks.
Previous Topic:Problems exporting SketchUp as an.stl
Next Topic:Best Way to Hollow out Objects
