| Greetings Shapwayers (is that a word?) [message #45625] Sat, 17 March 2012 19:52 UTC |
What a fantastic place.
1) What brings you to Shapeways?
I heard about Shapeways from a person inquiring about my software product - CadTempo. I had previously created some models for a couple of customers and had them 3D printed through a local source. Discovering the world of Shapeways you might say I had an epiphany and thus was born the name of my shop: Epiphany
2) Where are you from?
I'm from Rockford, Illinois. Born and raised, will it be my final resting place? Hopefully no, but I may not have control over that.
3) What are your interests or hobbies that you plan on using Shapeways for?
I'm looking forward to exploring my artistic side with Shapeways. Time will tell if I actually have an artistic side.
4) Your software
I have used AutoCAD for years in my main job function (which is machine design). Lately I've been experimenting with Autodesk's 123D Beta and Inventor Fusion. The two models currently in my shop were first created with AutoCAD (yes, it does do 3D modeling) and finished in Inventor Fusion. I found Inventor Fusion to be more powerful than 123D.
5) Your experience level
As mentioned, machine design is my backgroung so I typically work with things that are a much larger scale than what 3D printing will produce. I can certainly see the potential and value that 3D printing brings forth.
Finally, may I ask your opinion on something? The two models shown in my shop utilise a hook for hanging an item. I'm thinking of modifying them to be a little more unobtrusive. What do you think?
Regards to all, Patrick
Patrick Hughes
www.engds.com
| Re: Greetings Shapwayers (is that a word?) [message #45631 is a reply to message #45625 ] Sat, 17 March 2012 23:58 UTC |
Welcome, welcome.
Here's one suggestion for a less obvioius hanger.. if your object is suspended from a a string, then the knot (or a bead strung on the string) would not pass thru the hole, and support the object without having the hook.
Attachment: hanger.jpg
(Size: 21.49KB, Downloaded 119 time(s))
| Re: Greetings Shapwayers (is that a word?) [message #45637 is a reply to message #45631 ] Sun, 18 March 2012 01:06 UTC |
Hi Stony, thanks for your reply.
Actually my item contains a hook for something to hang from, rather than the way you are thinking. Have a look at one of my Cube displays, you'll see what I mean.
Patrick Hughes
www.engds.com
| Re: Greetings Shapwayers (is that a word?) [message #45639 is a reply to message #45637 ] Sun, 18 March 2012 02:45 UTC |
Oh, and by the way.. it's sometimes "Shapies".
| Re: Greetings Shapwayers (is that a word?) [message #46376 is a reply to message #45625 ] Tue, 03 April 2012 15:00 UTC |
Welcome to Shapeways! When I ran the Baltimore meetup in February, I called out to all Shapies Shapers Shapetes and Shapologists. But the general conscientious is Shapies. As far as your hook, perhaps something like stonys input, a ring with a gap to attach whatever you're attaching. Would a ring look less obtrusive?
Not sure how far you are from Chicago, but a meetup may be coming soon?!?
| Re: Greetings Shapwayers (is that a word?) [message #46377 is a reply to message #46345 ] Tue, 03 April 2012 15:03 UTC |
Thank you Charlotte,
I think you've put your finger on it, modifying it to blend in better. I had the same thought and I've got an idea on how I want it to look.
@stonysmith, I don't know why I didn't see your picture before but I do now. That's a good approach.
Patrick Hughes
www.engds.com
| Re: Greetings Shapwayers (is that a word?) [message #46379 is a reply to message #46376 ] Tue, 03 April 2012 15:07 UTC |
Thanks Michael,
I'll keep an eye out for the Chicago meetup. I'm about 60 miles from the city outskirts.
Patrick Hughes
www.engds.com
