| Re: A few quick questions for Shapeways ... [message #45404 is a reply to message #45396 ] Tue, 13 March 2012 12:36 UTC |
Hi Jasper , your question is rather vague , do you intend to cast the silver yourself ? in which case are you looking to get a mould or more correctly a die printed ? incidentally you will need a temperature 100°C above the melting point of 960°C for pouring.
Dan.
| Re: A few quick questions for Shapeways ... [message #45408 is a reply to message #45396 ] Tue, 13 March 2012 12:52 UTC |
Hi Jesper,
To answer your first question, you can use the free version of Sketchup for 3D printing.
-Marcus
| Re: A few quick questions for Shapeways ... [message #45413 is a reply to message #45408 ] Tue, 13 March 2012 14:58 UTC |
| denali3ddesign wrote on Tue, 13 March 2012 12:52 | Hi Jesper,
Well, you can't upload Sketchup files. You need DAE or STL from Sketchup I believe.
| Re: A few quick questions for Shapeways ... [message #45428 is a reply to message #45396 ] Tue, 13 March 2012 17:45 UTC |
Unless you are working in Full Color Sandstone, the DAE's exported by sketchup will work fine. (File/Export/3d Model)
However in sketchup 8 I've run into two hiccups. The first is the orientation of my models are always one axis off. IE: The front of my model in sketchup is the top of my model when uploaded to shapeways. This is not really a problem just something to be aware of. The second is if you upload a model with unexploded components, it returns an "unknown_size" error. So make sure you explode any components before you export your model.
[Updated on: Tue, 13 March 2012 17:46 UTC]
