Home » Community » 3D modeler needed » need : 3d model of a DOUBLE HELIX SPRING
icon3.gif  need : 3d model of a DOUBLE HELIX SPRING [message #44761] Fri, 02 March 2012 09:08 UTC Go to next message
avatar vinshi  is currently offline vinshi
can someone create for me a "DOUBLE HELIX SPRING" model (like the dna spring) made out of stainless steel\music wire
round circle (like a ring) at the bottom and top , one wire spiral from the bootom side circle , and second wire spiral from the paralel side bottom circle , both connected also at the top ring. measurments about 100mm high , about 40mm outside diameter , wires thickness about 2mm , distance from one spiral to the other about 3mm
how much for such job?
thanks !
[Updated on: Fri, 02 March 2012 10:40 UTC]
Re: need : 3d model of a DOUBLE HELIX SPRING [message #44766 is a reply to message #44761 ] Fri, 02 March 2012 12:15 UTC Go to previous messageGo to next message
yes though shapeways may refuse 2mm spring in stainless. 3mm is minimum spec you can try though. will pm you the part.
Re: need : 3d model of a DOUBLE HELIX SPRING [message #44767 is a reply to message #44766 ] Fri, 02 March 2012 12:26 UTC Go to previous messageGo to next message
3mm will be fine also
Re: need : 3d model of a DOUBLE HELIX SPRING [message #44768 is a reply to message #44766 ] Fri, 02 March 2012 12:32 UTC Go to previous messageGo to next message
the address is not working.. it says Invalid model id: 92162
Re: need : 3d model of a DOUBLE HELIX SPRING [message #44770 is a reply to message #44768 ] Fri, 02 March 2012 12:54 UTC Go to previous messageGo to next message
Sorry deleted 1 to many digits should be a2 or 3 in front of number
Re: need : 3d model of a DOUBLE HELIX SPRING [message #44771 is a reply to message #44770 ] Fri, 02 March 2012 12:58 UTC Go to previous messageGo to next message
doesnt work.. can you send the address again?
Re: need : 3d model of a DOUBLE HELIX SPRING [message #44772 is a reply to message #44770 ] Fri, 02 March 2012 13:03 UTC Go to previous message
2 in front of the number is invalid and 3 in front of the number says : Sorry, you don't have permission to perform this action
Previous Topic:Delete me
Next Topic:Molder needed for action figure accessories
