Home » Support » 3D Design » Textures not showing in renderer
Textures not showing in renderer [message #43944] Mon, 13 February 2012 17:54 UTC Go to next message
avatar 3dPrintingNoob  is currently offline 3dPrintingNoob
I've made four head models using the same process. The heads have a texture for the eyes and the skin for a total of three textures. The first two models I did worked fine. The textures show in the Shapeways renderer correctly.
The second two, however, don't show the textures. They only show the hair color which is simply a material.
I've attached screenshots of all the models.
Any idea what's going on? I've looked at the x3d files using notepad. I don't see any obvious difference to how they reference the textures. Also, the textures show fine in Blender before export.
Any help getting the textures to show will be greatly appreciated.
index.php?t=getfile&id=14586&private=0
  • Attachment: heads.jpg
    (Size: 99.83KB, Downloaded 145 time(s))
Re: Textures not showing in renderer [message #44125 is a reply to message #43944 ] Wed, 15 February 2012 21:17 UTC Go to previous messageGo to next message
So, I think I may have narrowed this down. I experimented with the file names a bit.
I started from scratch on head 3. I gave it the same file name as head 2. Textures appeared in the shapeways renderer. I started from scratch many more times playing around with various other names and the textures appeared. I started from scratch one last time and used the initial file name that the textures didn't work with. Sure enough, the textures didn't work again.
So, I know this has something to do with the file names. What I'm not sure of is what the constraints are with the file names that are causing me problems. I'll keep trying to figure it out.
Does anyone happen to know offhand of any restrictions to filenames that cause problems with textures?
Re: Textures not showing in renderer [message #44126 is a reply to message #43944 ] Wed, 15 February 2012 21:21 UTC Go to previous messageGo to next message
There shouldn't be any. I'd post the details in http://feedback.shapeways.com cause this appears to be some sort of bug.
Re: Textures not showing in renderer [message #44596 is a reply to message #44125 ] Tue, 28 February 2012 14:05 UTC Go to previous message
Can you share which texture names work and which don't? Do the non-working ones contain 'strange' characters like spaces?
Previous Topic:Unsure About Shells
Next Topic:Rhino --> STL problem, how can I make Shapeways accept my model?
