Home » Support » 3D Printing » Full color sandstone back-lighting and wall thickness
Full color sandstone back-lighting and wall thickness [message #44177] Sun, 19 February 2012 12:16 UTC Go to next message
Can anyone give me any insights into wall thicknesses and back-lighting FCS?
Also at what point does the print process smooth out faces?. I want to print a smooth sphere without going overboard with faces.
thanks everyone
bvr
Re: Full color sandstone back-lighting and wall thickness [message #44351 is a reply to message #44177 ] Thu, 23 February 2012 01:15 UTC Go to previous messageGo to next message
Back lighting is going to be tough at the minimum wall thickness of 3mm. The material is basically plaster so you will need a bright light to make this work. If you have a fairly wide opening on the bottom you could use something like this 3-watt, wide-angle LED module.
A sphere is a very strong shape, and I'm sure it could easily be printed about 1.5 inches wide at 1.5mm thickness for your application, if the opening was reinforced.
I would not worry too much about faceting. Making the faces about a millimeter wide would be fine.
Re: Full color sandstone back-lighting and wall thickness [message #44352 is a reply to message #44351 ] Thu, 23 February 2012 01:47 UTC Go to previous message
aeron203,
Thanks for the input. My "test" model will be 10cm in dia., with the full size model being as big as I can get it printed(20cm in dia). So, I imagine 3mm wall thickness will be required.
The led module is what I was planning on using. Now after your input I may try to source a brighter module.
Thanks for the tip on the faceting. This is going to be a pricey test piece so I'm trying to get as many of the variables correct before I commit to it. Unfortunately blender has thrown me a curve and as it is right now I can't get it printed correctly.
thanks much for the input.
bvr
Buffalo, 360° @ a time
Previous Topic:Color sandstone
Next Topic:Content of stainless steel sealant?
