| Printing Disjoint Objects [message #43508] Sun, 05 February 2012 22:25 UTC |
Hello everyone!
I was thinking of using shapeways to create a few various small things that I need. I was wondering if I could design each part disjoint from the other in one file, so I would only have to upload that single file. Can the parts be completely separate from eachother? Or would I have to attach them all together in some way. (Think of a plastic model airplane, with each part held by small tubes of plastic. Are the tubes needed, or can i just make the parts)
| Re: Printing Disjoint Objects [message #43517 is a reply to message #43508 ] Mon, 06 February 2012 04:53 UTC |
You don't have to connect them, but you risk not getting all of them due to human error, particularly if they don't appear to go together. Some other members have reported problems with this. Shapeways has been good about re-printing, but I think I speak for the community that we don't want to push our luck. I'd have to re-design a number of things if I had to sprue all the parts together.
Earl Grey, hot.
| Re: Printing Disjoint Objects [message #43539 is a reply to message #43517 ] Mon, 06 February 2012 15:34 UTC |
The other option, if you have a large number of small parts, is to put a "bounding box" around them such that the box has holes for the support material to escape, but the parts themselves won't fall out.
Unfortuntately, for many designs, the box itself may be more material than the parts.
[Updated on: Mon, 06 February 2012 15:40 UTC] Patience, Persistance, Politeness - the 3Ps will help us get us to Perfect Printed Products
| Re: Printing Disjoint Objects [message #43542 is a reply to message #43539 ] Mon, 06 February 2012 16:01 UTC |
I think I'll do something similar to the model airplane example I used, with the parts attached with thin, easy to remove tubes. How thin can I make the attachment points without having to worry about them falling off or not fusing at all. I will be using WSF material btw.
| Re: Printing Disjoint Objects [message #43556 is a reply to message #43542 ] Mon, 06 February 2012 17:51 UTC |
One thing.. you said "tubes".. they don't need to be hollow.
As to the size.. they need to be large/strong enough not to pull apart during cleaning, so the needed size can vary quite a bit.
I work in 1:220 scale, and connecting sprues between 1.0mm and 1.5mm seem to be strong enough to work just fine. But, if youre building larger items (say longer than 10cm) then your sprues will need be thicker.
