Price really high for no reason?
Price really high for no reason? [message #43450] Sat, 04 February 2012 16:04 UTC Go to next message
avatar asdfghjklasdfghjkl  is currently offline asdfghjklasdfghjkl
Hi, I've just uploaded a model, with sizes of:
10.3 w x 6.0 d x 11.1 h (cm)
But it's not a solid, it's only a triangle with a lot of free space inside. The only thing that's there is three walls of 3,5mm thick and 11,1 mm long. So it forms a triangle.
You can view it here:
http://www.shapeways.com/model/463725/microfoon_flag.html?gi d=ug
It says the price for White, Strong and Flexible is 85,36 euro / 112,46 dollar but only the material cost counts, right? Not the dimensions itself.
Please respond because I don't understand it...
Thanks.
Re: Price really high for no reason? [message #43453 is a reply to message #43450 ] Sat, 04 February 2012 17:39 UTC Go to previous messageGo to next message
You are going to be dissapointed if you are trying to compare the cost of 3d printing to that of injection molding, or purchasing bulk styrene stock and building such a structure with a few quick cuts.
The item you're trying to model is a significant volume of material
For each face:
110mm x 3.5mm x 60mm = 23100mm3 = 23.10cm3
so: 23.10cm3 = $33.84 in WSF for just one face.
Three faces would be $98.52, not counting overlapped areas.
One choice would be to select a different material... it'd be $55 in FCS.
But, I'd consider making the item thinner.. if it's truly a flag for a microphone, then you only need 1mm thick, which would drop your whole cost down to about $30
Then, if you were to start poking holes in each face, you'd drop the price even more. If you are looking for a specific logo on each face, you might consider cutting the logo as holes all the way thru the face.. and might be able to cut the cost by as much as 50%
Re: Price really high for no reason? [message #43455 is a reply to message #43450 ] Sat, 04 February 2012 18:00 UTC Go to previous messageGo to next message
avatar gharryh  is currently offline gharryh
I made a drawing in Alibre and uploaded the whole thing here <a href=http://www.shapeways.com/model/463826/test.html?gid=ug target=_blank></a> and it costs o lot less.
But as stonysmith replies its the volume of matarial used that counts.
Harry
[Updated on: Sat, 04 February 2012 18:02 UTC]
Re: Price really high for no reason? [message #43456 is a reply to message #43455 ] Sat, 04 February 2012 18:18 UTC Go to previous messageGo to next message
Harry: that's a bad link.
Re: Price really high for no reason? [message #43460 is a reply to message #43456 ] Sat, 04 February 2012 21:37 UTC Go to previous messageGo to next message
Sorry had the item on private. The link is correct.
Re: Price really high for no reason? [message #43495 is a reply to message #43453 ] Sun, 05 February 2012 16:40 UTC Go to previous messageGo to next message
But is it the quantity of the material that counts or the dimensions of the whole thing?
Re: Price really high for no reason? [message #43560 is a reply to message #43495 ] Mon, 06 February 2012 18:28 UTC Go to previous message
asdfghjklasdfghjkl wrote on Sun, 05 February 2012 16:40
With the exception of the Glazed Ceramic, all material prices are computed on Volume of material used. (GC is based on surface area).
Previous Topic:ceramics pricing question
Next Topic:Ceramic Glaze on Part Bottom
