| 3D modeler needed for cookie cutter [message #41741] Thu, 12 January 2012 09:13 UTC |
Can somebody help me to make this as a 3D file that shapeways can make a cookie cutter for me?
email: vanhaarlem10@hotmail.com
[Updated on: Thu, 12 January 2012 09:13 UTC]
| Re: 3D modeler needed for cookie cutter [message #41750 is a reply to message #41746 ] Thu, 12 January 2012 11:50 UTC |
Hi V, the length of the smallest leaf is 18.5 cm and the largest leaf is 28 centimeter (europian sizes)
Can you please help me?
| Re: 3D modeler needed for cookie cutter [message #41759 is a reply to message #41750 ] Thu, 12 January 2012 13:26 UTC |
We'll need a thickness as well for a 3D model. How thick do you want the leaf and do you want it rounded at the edges at all?
| Re: 3D modeler needed for cookie cutter [message #41765 is a reply to message #41759 ] Thu, 12 January 2012 14:19 UTC |
The thickness have to be 1,5 cm and the bottem have to be sharp, the edges have to be sharp too
[Updated on: Thu, 12 January 2012 14:19 UTC]
| Re: 3D modeler needed for cookie cutter [message #41781 is a reply to message #41746 ] Thu, 12 January 2012 16:35 UTC |
I have an attachment which is an example of what I want.
That's what I mean by stainless steel.
Attachment: IMG_0363[1]
(Size: 2.08MB, Downloaded 55 time(s))
| Re: 3D modeler needed for cookie cutter [message #41783 is a reply to message #41781 ] Thu, 12 January 2012 16:48 UTC |
Hi it won't be sharp because of the 3mm wall thickness of printed steel, you could file the edge down, alternatively, use WSF, the sharpest the edge can be printed is 0.2mm which is enough to cut dough?
V
www.dotsan.com
| Re: 3D modeler needed for cookie cutter [message #43399 is a reply to message #41741 ] Fri, 03 February 2012 18:13 UTC |
If this is still active i can help.
