Unglazed? Unpolished?
Unglazed? Unpolished? [message #29919] Wed, 29 June 2011 19:15 UTC Go to next message
avatar ggunhouse  is currently offline ggunhouse
Is it possible to get something printed in UNglazed ceramic, or UNpolished steel? If so, how would I ask for that option?
Glenn
Re: Unglazed? Unpolished? [message #29920 is a reply to message #29919 ] Wed, 29 June 2011 19:44 UTC Go to previous messageGo to next message
You can't get anything made in unglazed ceramic as the glaze is basically the only thing that holds it together. Without it the models are too brittle to ship.
Unpolished stainless isn't offered and I don't see why you would want it. The "polishing" is meant to remove burrs from printing and excess support material. The models are actually still rather rough even though they're polished. Of course if you really need it you could ask support but I don't think it will be possible.
Re: Unglazed? Unpolished? [message #29923 is a reply to message #29920 ] Wed, 29 June 2011 21:28 UTC Go to previous messageGo to next message
The ceramic is fired multiple times, one of them to give it strength before applying any glaze. Check the blog post about ceramics, as well as the ceramics page. It could be possible, just not avaliable.
Re: Unglazed? Unpolished? [message #30093 is a reply to message #29919 ] Sat, 02 July 2011 05:47 UTC Go to previous messageGo to next message
i would love to have the option of ordering unpolished steel.... frankly there are some things that should be hand polished and not tossed around by machine...
Re: Unglazed? Unpolished? [message #30112 is a reply to message #30093 ] Sat, 02 July 2011 15:26 UTC Go to previous messageGo to next message
Some of the things I have had printed in steel came back unevenly, inconsistently, or overpolished. I would just like the option of doing the polishing myself.
As for the glaze, it looks to me like the glaze obscures details more than I'd like. I also like the look of "bisque" porcelain, and would like the option of producing objects with that appearance.
Re: Unglazed? Unpolished? [message #38348 is a reply to message #29919 ] Fri, 11 November 2011 00:44 UTC Go to previous messageGo to next message
avatar jjohnsen  is currently offline jjohnsen
Apparently there's a lot of interest in un-glazed ceramic out there. I am really into the option too. It's not a matter of the un-glazed being "too brittle to ship" as some claim. It seems to more about "sellability."
There's an extensive comment section here.
Nancy Liang (employee) says, "The structures are indeed shippable between stages. Currently, we decided to opt for glaze only because the finishing for the other pieces are very rough (doesn't have to do with shippability), and isn't very commercially appealing--also the pricing would probably be close to the glaze because we still need to spray on the pre-glaze. We will look into this and refine for later releases."
I'd say that this option appeals to a lot of people and who are the commercials if not us? Since Shapeways has just refined their ceramic processing, I'd say that now is an opportune time to release un-glazed options for ceramics. As part of this community, make your desire known and spread the word. I'm sure it's something that will be offered (at least in one of those "trial" periods) if enough people ask for it. I vote YES.
Re: Unglazed? Unpolished? [message #38445 is a reply to message #38348 ] Sat, 12 November 2011 12:35 UTC Go to previous messageGo to next message
avatar insideko  is currently offline insideko
Re: Unglazed? Unpolished? [message #39889 is a reply to message #38348 ] Tue, 06 December 2011 20:27 UTC Go to previous messageGo to next message
avatar bjornsyse  is currently offline bjornsyse
I would also be interested in unglazed ceramics.
Re: Unglazed? Unpolished? [message #39890 is a reply to message #29919 ] Tue, 06 December 2011 21:40 UTC Go to previous messageGo to next message
Sound like good requests to enter into and vote for with the new feedback tool here:
http://feedback.shapeways.com/forums/111989-shapeways-feedba ck/category/37902-suggestions-3d-printing
(At the moment you need to register separately for the tool, but if you use the same email as for the main site, it will be seamlessly integrated later)
Re: Unglazed? Unpolished? [message #42763 is a reply to message #29919 ] Wed, 25 January 2012 22:53 UTC Go to previous messageGo to next message
avatar quantie  is currently offline quantie
I'm also interested in unglazed ceramics.
Re: Unglazed? Unpolished? [message #43082 is a reply to message #42763 ] Sun, 29 January 2012 23:59 UTC Go to previous messageGo to next message
avatar Agent24  is currently offline Agent24
Apart from the obvious colour difference, is there anything else that would change when an item has no glaze?
Would the items be more accurate to the 3D design in terms of dimensions or would the "pre-glaze" cause the same effect (adding thickness and thus reducing detail etc)
Re: Unglazed? Unpolished? [message #43088 is a reply to message #43082 ] Mon, 30 January 2012 03:10 UTC Go to previous messageGo to next message
I'm interested to know that as well. I recently received a glazed model and was disappointed at how much detail was lost under what appeared to be a thick layer of glaze (which was also marred by a small pinhole defect). If the pre-glaze is necessary to the strength of the object, but does not obscure details as much as the final glaze, that would make it more desirable in my view.
Re: Unglazed? Unpolished? [message #43771 is a reply to message #29919 ] Fri, 10 February 2012 01:51 UTC Go to previous messageGo to next message
avatar MrGnome  is currently offline MrGnome
I posted the same question regarding unglazed ceramics back in October: http://www.shapeways.com/forum/index.php?t=msg&th=6843. In that post, I note the results of my communications with Shapeways:
Quote:
Unfortunately we cannot change the automated process, this means that we cannot tell when a model needs to be glazed or not, as our system does not support this.
So for the moment you will have to order glazed version.
Re: Unglazed? Unpolished? [message #43794 is a reply to message #29919 ] Fri, 10 February 2012 13:50 UTC Go to previous message
If it is requested enough on Uservoice it will be considered. http://feedback.shapeways.com/forums/111989-shapeways-feedba ck
Previous Topic:wall thickness big head - Sandstone
Next Topic:I need help with figuring out what the best material would be for my 3D print.
