Home » Support » Buying » Slight differing of online preview vs model, should I worry?
Slight differing of online preview vs model, should I worry? [message #41682] Wed, 11 January 2012 16:00 UTC Go to next message
avatar fpad77  is currently offline fpad77
Hi All
I just wanted to check in about a bit of a worry on the model I've put together and just ordered.
I'm getting a small mishap in a element of the model where two parts were fused together which appears fine in both 3ds and Accutrans. I've checked over the textures and can't see any reason why it would be happening so just wanted to get a second opinion.
Here's the model in Accutrans:
http://img819.imageshack.us/img819/6734/preview1k.jpg
But in the online preview, it looks like this:
http://img534.imageshack.us/img534/9028/preview2a.jpg
As I said, this is from where the 2 parts were joined together (there's a second minor glitch there on the other model too), but it should be fine and I'm hoping its just a glitch on the online previewer. Any thoughts?
[Updated on: Wed, 11 January 2012 16:00 UTC]
Re: Slight differing of online preview vs model, should I worry? [message #41692 is a reply to message #41682 ] Wed, 11 January 2012 18:20 UTC Go to previous messageGo to next message
How are they joined? if they just sit face to face, that'll cause issues. If they sit inside of each other, shapeways will fuse them with no problem. My guess is overlapping faces cause the geometry to change, effecting the mapping.
Re: Slight differing of online preview vs model, should I worry? [message #41753 is a reply to message #41692 ] Thu, 12 January 2012 12:30 UTC Go to previous messageGo to next message
I don't get it - where are the two parts joined? Isn't this just a result of the viewing angle?
Re: Slight differing of online preview vs model, should I worry? [message #42015 is a reply to message #41753 ] Sun, 15 January 2012 22:29 UTC Go to previous messageGo to next message
Bart, it's a game of spot the difference - the hair on the one without the glasses - it also looks like the upper chest area of the one with glasses is a bit skewed Wink
Re: Slight differing of online preview vs model, should I worry? [message #42049 is a reply to message #42015 ] Mon, 16 January 2012 10:14 UTC Go to previous messageGo to next message
Ok, it looks like Mesh Medic has tried to repair some geometry there and in the processes damaged the UV mapping. Do you agree?
In such a case, the only advice I can give is to manually fix the geometry.
Re: Slight differing of online preview vs model, should I worry? [message #42872 is a reply to message #42049 ] Fri, 27 January 2012 12:00 UTC Go to previous message
Hi guys,
Sorry for late response. Yeah, it did turn up in print, but on the plus side I managed to fix it with a bit of recolouring and I'll know better next time!
Previous Topic:Partial delivery?
Next Topic:Large Quantity of items
