| Large Quantity of items [message #42702] Wed, 25 January 2012 09:45 UTC |
I have a small item that I built
http://www.shapeways.com/model/451896/tankbutton17mm.htm
I'm considering using it in the production of a product.
When I go to order 36 or 72 of them shipping stays at a flat $6.50. Can I be sure that I will receive all 72 items if I order that many and is this shipping accurate?
| Re: Large Quantity of items [message #42706 is a reply to message #42702 ] Wed, 25 January 2012 11:00 UTC |
Short answer: Yes.
But if you want 36 or 72 of this, I suggest to throw them in one file, and build a wire cage around them.
The additional material for the cage should be much cheaper than paying the handling fee 72 times...
| Re: Large Quantity of items [message #42707 is a reply to message #42706 ] Wed, 25 January 2012 11:24 UTC |
Sounds like a great idea. What do you mean by building a wire cage around them?
| Re: Large Quantity of items [message #42708 is a reply to message #42707 ] Wed, 25 January 2012 12:28 UTC |
Basically something like...
btw,
which material do you want use ?
Attachment: L.jpg
(Size: 66.26KB, Downloaded 208 time(s))
[Updated on: Wed, 25 January 2012 12:45 UTC]
| Re: Large Quantity of items [message #42713 is a reply to message #42708 ] Wed, 25 January 2012 15:01 UTC |
Hi Bryan,
You can sent all your questions about your models to service@shapeways.com and ask for Christel. I will help you further over there.
Christel
| Re: Large Quantity of items [message #42752 is a reply to message #42713 ] Wed, 25 January 2012 21:28 UTC |
@pfeiffer stylez: White Solid and Polished.
@ChristelH: Thank you, I certainly will.
| Re: Large Quantity of items [message #43462 is a reply to message #42752 ] Sat, 04 February 2012 21:50 UTC |
It normally IS a good idea to use such a cage, but there's a small problem here.. the cage idea is NOT good for polished materials.
For polishing, all surfaces of the object need to be exposed inside the polisher. In such a cage as this, the items will "fall" and touch each other face-to-back, and the polishing material will never get between the discs, defeating the ability to be polished.
