| Model not uploading to correct size. (3ds Max 8) [message #41471] Sun, 08 January 2012 21:04 UTC |
I have a problem I can't seem to fix myself :\.
I have a model that I made in 3ds max 8, the dimensions of the object as shown in Max is 25cm,1.55cm, 0.774cm. yet after upload the size is 3.3 w x 2.0 d x 1.0 h cm.
I don't know if this is something I'm doing wrong of perhaps a setting somewhere that is not right. I tried creating a simple test box, but is has the same problem.
So if anyone know whats up with this I would love to know.
Karcov
| Re: Model not uploading to correct size. (3ds Max 8) [message #41511 is a reply to message #41471 ] Mon, 09 January 2012 14:31 UTC |
What file type are you exporting and uploading?
| Re: Model not uploading to correct size. (3ds Max 8) [message #41558 is a reply to message #41511 ] Mon, 09 January 2012 23:06 UTC |
I have tried both .STL and .OBJ
And I have played around with different size settings such as MM, CM Etc.
| Re: Model not uploading to correct size. (3ds Max 8) [message #42513 is a reply to message #41558 ] Sun, 22 January 2012 22:44 UTC |
I dont' use 3ds max but I have a copy of the free Gmax.
The only thing I could suggest is check your Preference Settings.
Maybe you where playing around with the 1 unit = 'x' box.
The screenshot is from Gmax
Attachment: gmax.png
(Size: 33.38KB, Downloaded 119 time(s))
[Updated on: Sun, 22 January 2012 22:47 UTC] jacantdesign@gmail.com
| Re: Model not uploading to correct size. (3ds Max 8) [message #42531 is a reply to message #41471 ] Mon, 23 January 2012 04:05 UTC |
Make sure your file unit system is the same as your interface units. When you go to customize user unit setup, make sure display unit scale is the same as System unit Setup.
